Not sure I agree with the wind resistance comment above (not seeing the relationship between BB height and the size of the "aero" footprint the rider creates).
I will say there are basically 2 schools of thought on BB height as it relates to CX. Higher is better or lower is better. And ultimately they come from different eras.
Higher is better is more euro, where the courses are very techincal and much more traditional. Back in the day, having a higher BB with clips and straps hanging off your pedal meant less of a chance of clipping a pedal over uneven ground with your foot out, and more height for clearance (hence why mountain bikes have higher BB's compared to road bikes).
Lower is better (within reason), is more of a modern take and more centered around US courses. They tend to be less technical (all racers ride the same course, not so in EU), so the course needs to have something for everyone (more or less). Lower BB's feel more stable, especially in corners, which US style courses tend to have alot of, since they are often set up in a relatively small area. The down side is the aforementioned clipping of pedals and reduced clearance over obstacles.
My take, as a US based rider is, the sweet spot is around 68-70 of BB drop. I believe CXM did an analysis a few years back and came to a similar conclusion. But again, they are a US centric magazine.
If you are having a custom steel frame made for you, my suggestion would be to speak with your builder about it and discuss what the pros and cons are of the options available to you. As long as the bike isn't lugged, you should be able to balance out all the attributes to come to a drop that produces the desired results.
