1 - 10 of 10 Posts
I just purchased a new Trek Madone 5.2. I had read a lot about how the breaks are very stiff and take some time to get used to. On my ride my tire blew up on me. I haven't even put 200 miles on the bike yet. I'm going to take it back to the shop and see if they can hook me up with a free/cheap tire. I've never had a tire blow up on me before. Any advise on how to prevent this in the future would be greatly appreciated!
as far as I can tell they weren't. I didn't feel a difference in the ride, but with being a new bike there's a possibility. That was my first thought too. The brakes are built into the frame itself on the bottom of the frame. It's a weird set up, but it's supposed to be aero
It depends on how it "blew up".
If your brake pads were rubbing the sidewall there would be damage to the tire.
OTOH, maybe it was just a crap mounting job by the shop. I had this experience at Performance once. Had them overhaul a really old bike. Couple days worth of riding and the tire blew clean off the rim. Turns out they don't know how to mount a tire/tube and the tube was pinched between the tire and rim. It eventually bulged out and blew..about 50 yards from my car.
'brifter' is f'ing stupid
you really don't give any details in your post...no photos, no real information. did it blow off the rim? did you just get a puncture or a pinch flat? i have to say it's odd that you'd get 200mi on the bike before this happened, but you never know.
where did you read that the BRAKES were 'stiff'? and again...why is this post about a TIRE problem not in the 'wheels & tires' section?
First you need to tell us what "blew up" means. Was it the tire or tube? Top, bottom, side? Pinch flat or puncture?
If you rode over a piece of glass, why would you want a free tire from the shop?
Proud luddite
Oddly enough, I was shopping at a Performance once and heard what sounded like a gunshot out in the parking lot. Turned out that a customer was test riding a bike when the tire blew. Same deal...it was poorly mounted, the tube was bulging from beneath the wire bead and it went. I don't trust the guys at Performance to do any work on my bike, that's for sure.
Matnlely Dregaend
A tube failing within a couple of hundred miles is almost always a pinch flat from improper tire mounting. The truth is that we've all done it... mount a new tube, check it isn't pinched between the rim and the tire, and try again!
1 - 10 of 10 Posts
