There's enough variation in different manufacturers' tires that trying get to within a millimeter accuracy is futile. Are you only concerned about the tubes fitting? If so, no worries. Many tubes start at the smallest widths with a range of 18-25mm or 20-28mm. You could safely use the smallest tubes with the biggest cross or hybrid tires, the only problem being that as the tube stretches the wall thickness decreases, making it slightly easier to puncture (this doesn't necessarily mean you will see more flats). Tubes sized for tires above 25mm width can also often be crammed into a smaller tire, you just have to be more careful about pinch-flatting the tube when reinstalling the tire. Though this is more info than you need, basically sizing tubes to tires is hardly exact; you simply want the tube size within the ballpark to make it fit.
