So, I have been enjoying my first set of 23mm wide rims (HED Belgium C2) for the past 6 weeks or so. I run 25mm tires on them, at 100-105 PSI. All my other wheels are 19mm wide, and I've always ran 23mm wide tires at 120psi...and continue to do so on those wheels.
During my ride on Sunday I hit a razor blade and slashed my rear tire. All I have on the shelf are 23mm wide tires, so I threw one on. I have yet to ride then since I put the narrower tire on but my question is about the pressure. Should I pump this 23mm tire on the 23mm rim to the same PSI that I run the 23mm tire on the 19mm rim?
If so, I will likely just stick with 23mm tires for all the wheels...makes it easier to keep things in stock at home.
Thanks in advance.
Dan
Thanks in advance.
Dan
