Here is a Michelin chart. - TFlucky13 said:Newbie to road riding. I have a Cannondale Six13 1. My question is what tire pressure should I have my tires set at?
You told us the brand of bike, which is about as relevant as its color. The two key factors are tire size and rider weight. That said, 110 is on the high end. One school of thought is 90-100 psi, and if you get pinch flats, you need bigger tires. You will find people who pump to 140 and higher, but IMO they are nucking futs.lucky13 said:I just put it too 110 psi is that too much
I'm with Kerry on this...if I were racing, I MIGHT go higher, but I've been a recreational rider for more than 30 years, and I've pretty much settled on about 80psi in 35mm tires at my 240 pounds. I have 28s on one bike, and run those at 100-105, but I find myself walking past it more and more to get to the Atlantis.Kerry Irons said:You told us the brand of bike, which is about as relevant as its color. The two key factors are tire size and rider weight. That said, 110 is on the high end. One school of thought is 90-100 psi, and if you get pinch flats, you need bigger tires. You will find people who pump to 140 and higher, but IMO they are nucking futs.
