1 - 3 of 3 Posts
Hello,
I ve done a little searching and couldnt come up with the answer.
Should I base my tire size (ie. 20, 23,25 and 28mm) based on my weight?
I weigh between 145 and 155. Is there a better size choice for my size?
Thanks!
Gall
23's are what you want. I'm a fatty (180lbs) and ride 23 front 25 rear. Do you race or rec ride? Clinchers or tubular? Also, just cause a tire says 100-130 psi for example doesn't mean you can't ride at your weight at 90 psi. Fool around with tie pressure to see what feels best for you. There is a chart that will tell you pressures based on rider weight. But it's not the bible. I'll see if I can dig it up.
1 - 3 of 3 Posts
