1 - 8 of 8 Posts
I have a Trek 1980 400 series that I am restoring, the tires are in pretty good shape but do not hold air, I cant imagine they had tubeless in the 1980's, they are 27x1 1/8 can I throw a 700c tube in there?
what i thought, thanks MT Road, its a presta, will a schrader fit as well?
tires are pretty good shape, presta in there now, guess that means presta to replace
Rub it............
The schrader valve might be to large for the valve stem hole in the rim. If it only fits the presta valve, you can drill it out with a 5/16" drill bit to make it fit a schrader valve.
Resident Curmudgeon
If the tires are from the 80s I would not trust them regardless of how they looked. In fact, I wouldn't trust tires that were much older than 6-7 years.
You don't want to use Shrader valves anyway. They're a PITA with high-pressure road tires. The presta valve is designed for that use, and works much better.
For narrow road tubes, presta is easier to find, anyway, and usually cheaper.
1 - 8 of 8 Posts
