Bolt is aluminum
samh said:
I have a threaded Cinelli Grammo stem. Do I tighten to same or less torque as a non-titanium bolt for the expander bolt?
I had a couple of Cinelli Grammo Ti stems "back in the day". I am pretty sure the expander wedge bolt is Zicral alloy (aluminum). I just torqued it down like any other expander bolt, which for me means without a torque wrench. I just used my trusty Bondhus 6mm allen wrench, that has a handle of ~ 15 cm.
A Grammo-related tip: be sure to use a lot of grease/anti-seize on the handlebar clamp bolt with this stem. The bolt tends to gall in the Ti threads and Ti collar that houses it. This will give you a false sense of tightness and then the bars will slip.
If the stem is new to you, be aware that there were 26.4 and 26.0 bar clamp versions out there. The clamp diameter should be stamped on the quill.
