1 - 12 of 12 Posts
ride-a-holic
How do you use a torque wrench to get the required amount of torque. Is there some secret way of attaching this park tool to the wrench?
Kant phuckin sphell
Do you really need to torque it....
with a wrench?
If you have a torque wrench and you are unsure of how much force to use you can go practice on a lugnut on your car or something until you feel comfortable enough with about how much pressure to put on it.
wut?
Do you really need to use a torque wrench? Why not? If you have it, use it. That's what it's for.
And don't experiment on your car. If your put too much torque on a lug nut you could warp the brake rotor. It's actually possible that your BB torque spec is too high for your lug nuts.
Park makes tools like this that attach to your wrench...
I don't believe their is an attachment available
There are some available attachments for the Park torque wrenches (like cone wrence ends for headsets, hubs, etc.). I have not seen one for the external BB's like Gigapipe or MegaExo. I just checked the Park website and the only tool they have for these bottom brackets is the BBT-9 (which is what I use). In fact, I believe they have discontinued manufacturing the attachments entirely.
The FSA recommended torque for the MegaExo cups is only 29-36 foot lbs. This is less than the recommended torque on the fixing bolts for my stem attaching to the carbon steer tube. I would suggest using that (or other 50 ft lb or less bolts) as a guide for the amount of torque to apply.
Resident Dutchbag
I think the torque specs for the fixing bolts are given in inch lbs. One more reason why I prefer to use Nm, no confusion.
Shimano makes the tool, I believe it fits a 3/8" socket. Its called the TL-FC33
Part # Y13009230
Duh...
absolutely correct. Thanks for catching this.
Kant phuckin sphell
Dont think.....
the torque required for any Bottom Bracket (around 35 ft-lbs) will ever be anywhere near the amount of torque a wheel (around 80 ft-lbs) on a car will require, much less enough to warp a rotor. But I think I have seen some Bottom brackets installed at bike shops around here that might have warped a rotor. None the less if you are a ham-fist it would be a good idea to go get a feel of how much torque you are throwing down on a something before you go a install your new BB. https://forums.roadbikereview.com/images/icons/icon12.gif
ride-a-holic
Discussion Starter · #11 ·
The GXP..
says 34-41nm.
1 - 12 of 12 Posts
