Most pedals also have a hex opening in the end of the axle (get at it from the opposite side of the crank) that you can use to torque things properly instead of trying the crow's foot. Much easier, though to be honest, pedals are one of the very few things on a bike that I don't bother with torque spec for. Though I probably should.steel515 said:has anyone tried the pedal attachment (crow's foot)? I tried one from sears I think didn't fit
Actually many pedals DON'T have a hex slot in the axle. Compared to the appropriate force applied with a pedal wrench, a hex wrench is not the greatest way to install pedals. As to the proper torque applied when installing pedals, that's a good hard push on the pedal wrench. No need whatsoever for a torque wrench.bikeboy389 said:Most pedals also have a hex opening in the end of the axle . . . pedals are one of the very few things on a bike that I don't bother with torque spec for. Though I probably should.
Mel,Mel Erickson said:I prefer the clicker style wrench to a beam wrench. More positive, you know exactly when you've reached the proper torque. Difficult to over torque. Easier to set the torque you want (can't really set it with a beam wrench). Beam wrenches are usually longer and give you more leverage, this can be good and bad. Beam wrenches are typically cheaper and more durable (it's easy to re-center the needle) but less accurate.
I found this description, which I intepret as saying the Syntace is a clicker, on a seller's web site:Mel Erickson said:I know nothing about the Syntace. My clicker is an Mit Mechanics. It was a gift. If I were choosing I'd get a 3/8 Craftsman. Mainly because of availability and warranty and virtually all Craftsman tools are decent quality.
Do the Craftsman wrenches work with left hand threads (e.g. pedals, bottom brackets)? The one I am looking at (Model # 44596, 3/8 drive, 5-80 ft-lb range) has an arrow on the handle indicating that torque should only be applied in the clockwise direction. Is this typical for the click type wrenches? The ratchet head has a switch to reverse direction, but I don't know if it will read torque in that direction.Mel Erickson said:I know nothing about the Syntace. My clicker is an Mit Mechanics. It was a gift. If I were choosing I'd get a 3/8 Craftsman. Mainly because of availability and warranty and virtually all Craftsman tools are decent quality.
