1 - 3 of 3 Posts
I'm looking to buying a track bike in the next few days. I will be racing this bike at the velodrome so it does need to be track specific. It will be my only track bike.
One problem I have encountered with sizing is that most bike in my budget ($500-$600) come as follows:
57 cm seat tube with a 56cm top tube. Next size up is a 59cm ST with a 57.5 TT.
My road bike has a 58cm ST with a 58cm TT and a 11cm stem.
My question is, are track riders supposed to ride a little more crammed into the bike, or should the set up be the same as on a road bike?
Track bike sizing is typically smaller than road bikes. The old rule of thumb was get one size smaller than you would in a road bike. I think the smaller of the two sizes will work well, especially as you could put on a longer stem without getting too long. FWIW I ride 58.5 tt / 13 stem road, and 57.5/12 on the track, but remeber that the angles are all different, making direct comparison of lengths inaccurate.
I've been told the opposite as 'yeah right'.
my coach told me the "go smaller" thing is a common myth. he said it should be the same setup as your road bike. my track-guru friend also said that this is correct, so this is the way i'm going. now, if you can get the same setup form that size track bike, I don't imagine it will be a problem.
AFF.
1 - 3 of 3 Posts
