1 - 5 of 5 Posts
The frame I'm looking at is stock with standard dropouts and derailleur hanger, I will be setting the new bike up as a SS. Having the frame custom made with track ends is an option, for an extra $300. My current CX bike is set up with a White Industries eccentric hub, I have not had any problems with this set up what so ever. I was wondering if track ends would be any better than the WI eccentric hub? My last experience with track ends was on my BMX bike in the 80's.
I generally find track ends to be a PITA, so of those two options, I'd choose to save money and go with the ENO hub. However, if you're getting custom, why not get forward facing horizontal dropouts (like the Surly Cross Check)? These grip much better than track ends (no need for a chain tug, in my experience), and moving the wheel to adjust your chain tension doesn't affect your brake to rim relationship. It's simply a better design.
· Number 2 on the course.
IME (three ENO Ecc. hubs, 2 now converted to straight axles), the ecc. is a kludge. Then again, I would sooner choose vert. drops, a tensioner and QR axle hub for racing.
Track ends with nut tuggers; from homebrew components work great. Easy wheel changes with the nut tuggers, release the wheel and slide out with the nut tuggers and the nut tuggers are then preset correctly when you put the wheel back on. Or paragon sliders.
I have the WI eccentric hub and it works well but wheel changes are not as simple as with a frame with track ends and nut tuggers.
$300 for an "upgrade" to track ends sounds like a lot to me. These Black Cat drops were an extra $125 on my recent custom. Not sure if they come without the disc brake mounts or not. Very easy to adjust, and they don't slip.
1 - 5 of 5 Posts
