They do give a smaller standover height, but generally they are no better or worse than traditional level top tube designs. There are claims that the rear triangle is stiffer and that the frame is lighter, but generally it's marketing hype. The weight loss is offset by the longer seat post. The stiffness is offset by more flex in the post. Compact geometry was originally conceived to reduce the number of frame sizes needed. That was the original TCR designed by Mick Burrows for Giant. S M & L have given way to XS S M L & XL as they found that their theory was flawed. Most other manufacturers have merely sloped the top tube of conventional frames.Foye said:what are peoples thoughts on this. does it really make a difference? seems like the sloping frames are better for people with shorter legs. if they fitter a wider range of people, why are traditional sized frames still made?
C-40 said:If the jumps between sizes are greater than 2cm, there will always be folks who can't be fit without an odd stem length and/or angle, so compact geoemtry can create as many problems as it solves.
My #1 reason for prefering a sloping top tube is that I never have to adjust the seatpost height when I clamp my bike in the stand for maintenance. My #2 reason is I think a little slope provides a nice looking bike. Aside from that, no difference whatsoever.Foye said:what are peoples thoughts on this. does it really make a difference? seems like the sloping frames are better for people with shorter legs. if they fitter a wider range of people, why are traditional sized frames still made?
When I say "jumps between sizes", it means frame sizes. Frame size is a measurement along the seat tube. The most traditional is center to center, others may use center to top and the real oddballs like Trek and Fuji use the entire seat tube length, which is the least meaningful. The chart linked below is one of the best, where Pcc is the c-c frame size. For a sloping TT frame, there is still a c-c frame size to a "virtual" (horizontal) TT.Foye said:i am guessing that you are refering to the top tube length when talking about 2cm jumps?
Hi Foye,Foye said:what are peoples thoughts on this. does it really make a difference? seems like the sloping frames are better for people with shorter legs. if they fitter a wider range of people, why are traditional sized frames still made?
You can't just dispose of the geometry of a frame by saying that since the tubes are shorter, rigidity is better. That is simply not the case w.r.t. compacts. The tubes might be shorter, but they also form different angles in the frame. This directly impacts how the frame behaves.critchie said:The claims about stiffer rear triangles (and front ones) are mostly true and are not just marketing hype. True the weight may be offset by a longer seat post, however, it is not true that the stiffness is offset by more seat post flex. The seat post does flex more and that is one of the advantages -- that flex provides additional compliance and therefore additional comfort. It does not change the BB stiffness which is the important factor. More BB stiffness means the bike accelerates quicker. Let us also not forget torsional rigidity in this equation. The shorter tubes lengths of compact frames all help increase torsional rigidity.
No one just disposed with the geometry!!!!! See my quote:alienator said:You can't just dispose of the geometry of a frame by saying that since the tubes are shorter, rigidity is better. That is simply not the case w.r.t. compacts. The tubes might be shorter, but they also form different angles in the frame. This directly impacts how the frame behaves.
By geometry, I mean the angles between the TT & HT & ST; DT & HT & ST; ST & seatstay& chainstays. Those dimensions WILL change. They have to. If the seatstays and chainstays are exactly the same dimensions as they are on a standard frame, then the ST will have to have a different angle to close that triangle. By geometry, I don't necessarily mean HT and ST angles. To completely constrain a triangle you need three angles, three sides, or two angles and an included side.critchie said:No one just disposed with the geometry!!!!! See my quote:
I said mostly true. In addition, having a compact frame does not change the geometry. Geometries may be completely unchanged by having a compact frame -- the TT and seat tube may simply be shorter in length. Does this angle of the TT toward the seat tube and its inherently shorter length change the frames behavior -- not likely, but I am certain you will differ, and without any specific testing on a specific bike model using test equipment that is common to the bike manufacturers
Only two angles have to change in the main triangle of a compact frame -- the angle between the HT and TT, and the angle between the TT and ST. There will also be a different angle at the seat stay/ST junction and the angle at which the seat and chain stay converge. I doubt however that these changes have much/any effect on the finished product. Manufacturers must certainly change tubing (carbon, steel, Al, Ti, etc) slightly to account for any torsional changes that occur because of these minor convergence changes.alienator said:By geometry, I mean the angles between the TT & HT & ST; DT & HT & ST; ST & seatstay& chainstays. Those dimensions WILL change. They have to. If the seatstays and chainstays are exactly the same dimensions as they are on a standard frame, then the ST will have to have a different angle to close that triangle. By geometry, I don't necessarily mean HT and ST angles. To completely constrain a triangle you need three angles, three sides, or two angles and an included side.
So apparently compacts aren't necessarily stiffer, if manufacturers alter tubing. Hmmmmm. Back to the marketing thing.......critchie said:Manufacturers must certainly change tubing (carbon, steel, Al, Ti, etc) slightly to account for any torsional changes that occur because of these minor convergence changes.
What? Do you use, because surely you could not have gotten there from what I said. Maybe they make adjustments to decrease stiffness. This is not marketing!!!!!!!!!!! But think what you want.alienator said:So apparently compacts aren't necessarily stiffer, if manufacturers alter tubing. Hmmmmm. Back to the marketing thing.......
It's not a matter of thinking what I want to think. It's a matter of engineering and science. Using the exact same tubing in a compact and a standard frame, there's NOTHING that implicitly says that the compact will have a stiffer front or rear triangle. What determines that are the starting and ending tube lengths and angles. That's it. Compacts do NOT necessarily have optimal triangles. Saying that they are "mostly stiffer" is stupid at best, because it completely negates the effect of geometry. Changing tube types between a compact and a standard model completely negates any comparison w.r.t. compact vs. standard. It's that simple.critchie said:What? Do you use, because surely you could not have gotten there from what I said. Maybe they make adjustments to decrease stiffness. This is not marketing!!!!!!!!!!! But think what you want.
It is a matter of what you think! You have done NO engineering studies to indicate that a compact is not inherently stiffer, but you are telling me that it is a matter of engineering and science. Compacts may well have optimal triangles but I did not say they do, and you cannot say they don't.alienator said:It's not a matter of thinking what I want to think. It's a matter of engineering and science. Using the exact same tubing in a compact and a standard frame, there's NOTHING that implicitly says that the compact will have a stiffer front or rear triangle. What determines that are the starting and ending tube lengths and angles. That's it. Compacts do NOT necessarily have optimal triangles. Saying that they are "mostly stiffer" is stupid at best, because it completely negates the effect of geometry. Changing tube types between a compact and a standard model completely negates any comparison w.r.t. compact vs. standard. It's that simple.
Agree with Terry on #1. I generally ride a bike with a 57 top tube and 73 degree seat angle, but my saddle height is not that high. On a traditional frame that means I might only have 10 cm from the bottom of the saddle rails to the top of the seat tube clamp. That is why I prefer a frame with a gentle slope, usually about 5 cm off of what would be a square frame.terry b said:My #1 reason for prefering a sloping top tube is that I never have to adjust the seatpost height when I clamp my bike in the stand for maintenance. My #2 reason is I think a little slope provides a nice looking bike. Aside from that, no difference whatsoever.
Well, I don't have to do any studies because I'm not the idget parroting the marketing-speak. I didn't say that a compact was necessarily this or that. You did. And while it is true that a long tube will flex more than a shorter tube of the same material and diameter under the same LOAD, it is the geometry (i.e. "angles" for the Newtonian mechanics impaired) that determine how the tubes are loaded. THEREFORE, given the same forces and two frames that are exactly the same except for angles and tube lengths, NOTHING can be implicitly known without figuring how the loads are DISTRIBUTED due to the geometry.critchie said:It is a matter of what you think! You have done NO engineering studies to indicate that a compact is not inherently stiffer, but you are telling me that it is a matter of engineering and science. Compacts may well have optimal triangles but I did not say they do, and you cannot say they don't.
All the manufacturers claim compacts are stiffer, and it is obvious to even the retarded that a long tube is easier to bend then an equally made short one, so it stands to reason that a compact would be marginally stiffer. We can call it marketing, but unless you have your vaunted engineering and science studies to disprove the manufacturers claims, I am going to believe they are valid.
Lastly, my biggest reasons for liking the compact design were, the improved comfort gained from having the seat post extended and the flex that provides, and I like the asthetics better. Nothing more.
