1 - 4 of 4 Posts
So my 2002/2003 (not really sure) Ultegra rear shifter is sticking. Basically instead of shifting up by three when pushing all the way like normal it just goes by one gear and I have to press the small lever a few times to get it to shift the other way. (a few weeks ago the shift cable broke inside the shifter so I'm guessing its related)
Anyway I was wondering what 9 speed shifters would be good replacements. Should I try to find an Ultegra ST-6510 shifters (the last of the 9 speed Ultegra's from what I see) or use the current Tiagra shifter on the thinking that since its been so long the current Tiagra uses the same basic parts as the old Ultegra? Or is the some other option I should look at?
Try saturating the internals with WD-40 and working the shifter a bit. Sometimes this helps loosen up stick shifters (I've used it to resurrect quite a few road and mountain Shimano shifters over many years of being a bicycle mechanic). I would normally never recommend WD-40 on bikes...but this is one situation where it appears to work well.
Adorable Furry Hombre
There is a reason why WD40 is also known as "Shimano Brifter Overhaul in a Can".
1 - 4 of 4 Posts
