I broke my rear derailleur cable earlier this week and had to ride home using just one cog on the rear cogset. BTW, don't let your cables break on the 10 speed Shimano shifters, the pieces are a bear to get out!
So, to ride home, I adjusted the limit screw to the 16t cog in the rear and had three gears to choose from. That gear range worked remarkably well!
I have a single speed at home and like riding it, but never ride far since I am not a pedal masher and there are hills in Vermont. My franken-setup gave me a very usable range for both up hills, flats and down hills. I would think that this gear range would be sufficient for most of my basic commuting. Is there anything actually made like this? I know there are 3sp internal hubs, but they don't have the gear range I get with a 30, 44, 52 mated to a 16t. The one big problem is that if I ran an actually single speed rear hub, I would have to add something to adjust chain tension like a dummy rear derailleur. That would eliminate any benefits of the setup. Is there anything that could take up the chain tension with the front derailleur so that there is only one set of hard ware in the chainline?
I don't think I would really do this, but I was surprised with how happy I was with the gear range.
