1 - 20 of 23 Posts
I am getting ready to order a new Seven titanium bike and am trying to get some input from those of you that have done some touring. I already have a mountain bike (Specialized Epic) for single track and a road bike (Felt Z series) for straight road riding, but I want something that will work great for long gravel races/rides and possibly some touring on varied terrain with big climbs, perhaps loaded down with a moderate amount of gear. I haven't done the touring thing yet, but would love to be able to. I'm struggling with the decision about compact double vs a triple for the most versatility. I already have a SRAM 11-32 rear cassette that I could use, but SRAM doesn't make a triple. I have the compact double on my mountain bike, and love it, but I'm afraid I won't have enough gears for long, sustained climbs on a loaded bike. I'd also like to have something that would be easy for a small bike shop in the middle of nowhere to fix. I'm trying to learn more about bike repair, but have a ways to go.
I'm a 53 yo female, love riding off the beaten path, and have it in my head that loading up my bike taking off for a few days (or more) would be fun to do one day soon.
Recommendations?
given your touring aspirations, i think the triple is the way to go. my mechanic who does loooong touring rides (think, denver to minnepolis) geared his tourer with a triple that had a 48-36-26 ratio, iirc.
Two wheels=freedom!
For a jack of all trades set-up, I would go with a triple. You might want to think of something that has a low in the mid 20's, a mid in the 30's, and a high in the upper 40's/low 50's. I would think that your 11-32 is a good bit in the rear. You will need something akin to your MTB rear dear, you will need a long cage to cover that many gears. Ck out Grant and the crew at Rivbike.com have to say about gearing. I kinda avoid loading my tourer up and use a B.O.B. trailer for when I am looking to move a load. They are easy to take on and off and can handle a ton (well like 70 lbs) of stuff. When full loaded, I really appreciate the triple when going up long hills. YMMV
Cranky Old Bastard
Yes I agree, get a triple.
My first real road bike was a tourer with triple chainrings and even though I rarely used the little ring it was great to have it there. I passed many people pushing their bike up the hill while I was spinnin' like crazy!
Triple, just because you have it does mean you are obligated to use it. But when you need it, you will be glad to have it. I have not done any touring but my commuter bike is a triple and when I haul a load of groceries up the hill to my house (4.5% about 1/2 mile) after a long ride or week of training the granny ring is nice. May also permit a tighter cassette as well.
Super Moderator
Recommendations?
You're right to be concerned about not having enough gears for loaded touring without a triple. It's a very different kind of riding, carrying any amount of gear with any sort of climbing, and you'll need the extra gearing (not just the range) that a triple gives you.
beware as not all triples are equal. most road triples are 52/42/30. If you really intend to do self contained touring in the mountains, this is not what you want. Note what Dnice said about his friend. That is a rig made for the mountains. My Fargo which is dedicated to self contained touring has a similar gear combination. Check out adventure cycle organization.
Cranky Old Bastard
To give you an idea of how low some bikes go, my tourer (700c) came with 46/36/26 rings and a 13-30 cassette. The crankset was Shimano Deore, actually designed for mountain bikes.
I changed to a 48t big ring and 12-28 and liked that better.
Another quick point that just popped into my head: with triple chainrings and wide cassettes chain wear can be a problem because you can get extreme chain angles.
Not a huge deal, but I try to limit myself to only using around 6 cogs with each ring.
Seeking shades of grey
A lot of people say get the triple, but I personally would go for the compact unless your touring is specifically taking you lengthwise along a mountain ridge. The smoother shifting of a double is worth the decreased range in gears in my book.
Triple.
I'm of two minds about the gear combinations, and it somewhat depends on what your immediate plans are.
30/32 is a really low gear already. If you don't have immediate plans to load a bunch of stuff on your bike and tour, I think a stock triple (30-39-50 lately, I think) would serve you fine. Per Sheldon Brown, you can have as small as a 24t granny on one of these cranks. BCD is typically 130/74, which is a little weird, actually, and does give you a 38t smallest middle ring, for a pretty big shift from the granny to middle ring.
Velo Orange makes some attractive 110/74 cranks. That's nice because you can go to a 34t middle ring, like a compact. Think of it as being like adding an extra super-low climbing range to the compacts you're already accustomed to.
There are also a couple ways to do even lower. There are still some 94/58 cranks around. These will take a 20t ring.
Of course a mountain bike crank (104/64) is an option. That lets you go to a 22t small ring, and chainrings are very common.
For myself, I'd probably be leaning toward the V-O crank. I think that compact +granny would go low enough and I could gear the top two rings to match my other road bikes.
EDIT: FWIW, while I don't tour, I've used panniers to commute in my hilly city and used them to haul a bunch of stuff from San Francisco to Santa Cruz back in college. I really appreciate having low enough gears not to have to get out of the saddle on a bike with a bunch of extra crap strapped to it.
Cranky Old Bastard
It was 20 years ago so I don't remember the details but I experimented to improve the shifting with my triple setup.
I cut the chain shorter so that it wouldn't even fit on the big/big combination. I always watched what I was doing, only used about 5 cogs (or less) with each ring (as I mentioned before) and never had a problem.
I changed to a medium cage RD from the long cage. The medium worked great as I remembered to stay within its' range.
The shifting was better, crisper and faster, but not tremendously better. Noticeable, not night and day difference, I'd guess maybe 20% better.
And I ran it that way for a long time, worked fine.
I'm not suggesting a newbie try it, though.
A wheelist
A triple for sure Terrig. And be realistic in the ring sizes too. Who really needs a 52t ring for touring? Heck with a 50/14 I can do 30mph downhill. If it was me I'd be custom building something like a 46/34/24 with 13-32. In fact that's what I have on my mountain bike and I can average 18mph on smooth dirt roads. You won't be doing averages like that with any kind of touring load. That way you're not wasting precious gears.
Cranky Old Bastard
And just to throw this out there.
When I wasn't touring (IOW 99% of the time) I put a 12-21 on the hub and had nice close spacing on all the gears. Seemed like I always had the perfect gear for the situation.
With the granny I didn't need a big cog on the back when she wasn't loaded down.
At my age, looking cool in the eyes of others means less than nothing. Triples Rule!
Discussion Starter · #19 ·
Herbie ...sounds like your Fargo is set up to what I'd like to have the ability to do. I will also be doing longish, unloaded gravel rides, but I have just gotten rid of my carbon cx bike to order this one for more versatility. Open to more suggestions! (Without getting TOO technical!) Thanks.
Discussion Starter · #20 ·
Randy--thinking that no matter what my gearing is I will look way cooler riding my bike up a hill vs pushing it anyway! (Plus, I do have a very nice road bike and mountain bike that are way cool already--wanting this one to be my utility "take me to far away places off the beaten path" bike!)
1 - 20 of 23 Posts
