1 - 10 of 10 Posts
Discussion Starter #1
TruVativ bottom bracket keeps developing play. Has anyone else heard of this problem? If so, what did you do to fix it? I bought it new. It is Italian threaded if that makes any difference.
With the Truvativ setup, you MUST get the BB shell faced so there is proper alignment.
Discussion Starter #3
Faced-WHat exactly does that mean?
I've heard the term. But what does it mean exactly?
Resident Dutchbag
It means the outsides of your bottom bracket are "shaved" to be exactly parallel. This is important when you have the Giga-X-Pipe configuration. When you install the cranks, you should torque up to spec, get the crank loose again, regrease and torque up again and repeat untill there's no play at all, after that you'd probably have to refasten (get it completely loose again, regrease and torque up) one more time. These babies have extremely tight machining tolerances causing some initial hassle, after that they run in and run fine.
Discussion Starter #5
Thanks. Stuff like that is beyond me, so I took the bike to a shop-not the shop where I bought it. They should know about that and be able to fix it. My main concern is compatibility-I don't want to have to buy a whole new crank, bb and derailleur.
Resident Dutchbag
If you can patch a tube, you can learn most of the maintenance work on your bike. The secret is in knowing how. It's easier than you think when you start with the easy stuff. Here's a good starter for learning the how and what:
http://www.amazon.com/gp/product/1884737706/104-5463201-0835135?v=glance&n=283155
Discussion Starter #7
Unless you have the proper tools (they are $$$), DO NOT attempt to face a BB or headtube or chase any threads. Screwing up when installing parts is one thing, a dicked up BB shell quickly leads to a new frame!!!
Discussion Starter #10
Problem solved I think
I picked it up from the shop today. They had looked it up on the internet and read the directions. It seems fine now and only cost me $10 for the fix.
Hopefully it will not loosen itself again.
THanks everyone for the advice.
1 - 10 of 10 Posts
