1 - 7 of 7 Posts
Tubes are stretchy, so they fit a range of sizes. A 27 x 1" tire is only a little larger than a 23mm 700c, so the same tube works for both.
They need some kind of protection,
edhchoe said:
Thank you!
Another question... Do you carry the tubes with the box? It is rather bulky.
if you carry them in a seat bag with tools, tire levers, etc. Otherwise there's a good chance that when you need it, you'll find it has a hole torn in it. But the boxes are bulky, as you say. I repackage the tube in a heavy-duty ziploc bag, squeezing out as much air as possible, and then wrapping it with a couple of rubber bands to keep it all neat. The bag also allows you to dust the tube with talcum powder (aids installation), without having a mess. Partially inflate the new tube, coat thoroughly with talc, then completely deflate, roll it up and seal it in the bag. It'll be ready to go when you need it.
still shedding season
I've been buying Bontrager tubes at the LBS that I believe are marked 700x23 or 25, and 27 x 7/8 or 1. Something like that, not sure what actual brand they really are.
I've been leaving one in the box that I carry in my small seat bag. In the box I stuff a pair of disposable gloves and a stick-on patch kit - little piece of sandpaper with the grit side facing "out" so it doesn't rub on the tube. This way it all stays together.
1 - 7 of 7 Posts
