1 - 8 of 8 Posts
I read an article a long time ago that Michelin created prototypes of a road tire
which was tubeless like mountain bike tubeless tires. It required a special rim.
Does anyone know when it is coming out?
Any day now
steel515 said:
I read an article a long time ago that Michelin created prototypes of a road tire which was tubeless like mountain bike tubeless tires. It required a special rim. Does anyone know when it is coming out?
This concept was announced several years ago. At the time, the release date was "soon." That is still the case. :)
Similar
steel515 said:
Is this exactly the same as mountain bike tubeless tires and is it possible for such a design for road bikes?
Basic principles are the same. Given that road tires run in XS of 100 psi (7 bar), it is a lot more difficult to make things work. Also, the weight penalty that is seen in MTBs is not acceptable on the road. With an MTB, pinch flats are a common problem and so tubeless offers a solution to that problem. Pinch flats on the road are much less of an issue, so tubeless has less to offer the road rider.
In my book, it is a sign of quality (and the right design). I once had a set of Bontragers that you could use to peel vegetables.
Argentius said:
Is the reason that Campy, Mavic, etc, have their high-end clinchers requiring no rim-tape?
I mean, saving 15 grams from lack of Velox can't matter THAT much...
1 - 8 of 8 Posts
