21 - 40 of 43 Posts
No, same valves. You just push the tire aside at the top and squirt it in with a common plastic syringe. No mess at all; I occasionally get a little drip from the bottom before it's inflated, but it's not much.
I'm not sure why anybody puts the sealant in via the valve. I hang the wheel so it's not sitting on the tire, put the valve at about nine or three o'clock, put the pump on, then squirt the sealant in from the top. As soon as I'm done with the sealant, I immediately inflate.
No fuss, no muss.
there are valves out there where you can remove the core and it is easy to shoot the sealant in there (i don't know what brand makes tubeless valves with this feature). Shooting through the valve is a pain in the ass, but it can be done using either the stan's injector thing or an oral syringe and a piece of rubber tubing melted to size (i used drill bits and a lighter to expand some tubing i had that fit on the syringe, but not over the valve).
For mountain bikes i just dump the sealant in the side of the tire before i have it mounted on the rim, i haven't used road tubeless yet so i don't know how much harder this method is.
I run road tubeless (Stan's) and I have filled tires both ways. I do not find it a pain to fill through the Presta valve. The hard part is finding a proper sized wrench to snug it back up with and or unscrewing it. I found a cheap stamped wrench and filed it to fit so now it's easy. I pulled off a tire after running it 2 years, and found the sealant had dried out. I then decided to check a tire that had been running about 1 year and found it was fine, it didn't need anything. It would have been real easy to just pour some in the side by just pushing the edge of the tire over though.
pmt not sure how you were so successful but a friend and I tried putting on a tire and we were averaging at least 30 minutes. Found it very hard to seal the tire without any air in it, and even when using a syringe and some tubing the sealant was coming out of the bottom of the tire. Perhaps hanging it would help. Did you use the soap method to get the bead on? I found that the little granules in the sealant actually seemed affect the seal of the bead.
Martin are you using a 2 piece Presta valve as I can't imagine being able to snug the valve back into a Campy wheel without access to it from the inside rim.
Nah, I never bother with soapy water anymore. Haven't needed it. I use a simple syringe like this https://www.glowngrowhydroponics.co.uk/ekmps/shops/glowngrow/images/10ml.jpg and just push the tire aside at the top and inject it.
Hanging the wheel is important; Stan says to do that in his video as well.
For inflation, I use a Zefal Double-Shot pump, which slams air in quickly. No trouble seating and sealing the tire, now on five different types of rim (two Neuvation, Bontrager, Rigida, Velocity).
Saw the hanging bit on the video and perhaps that is more important then I would have thought. I think the fact that I have Campy wheels which are notorious for tight fitting tires, is not helping. I appreciate your responses to my question.
On an aside, I was out for a long ride yesterday and thought I had run over a milkweed plant as I had white liquid spray up from my back wheel. Realized shortly after that it was the sealant doing its job and saved me a puncture and flat!
A "Slime" bottle can be used too. It has the top that is pointed where you can push it between the tire and rim (with the tire partially off of the rim). You just point it in and squeeze and let it fall to the bottom of the tire and then pull the tire back onto the rim from the top. I then inflate the tire with a compressor or CO2 cartridge. The soapy water just helps the tire seat with less pressure. The Hutchinson tires seem to generally seat no problem anways and they hold air without sealant too. The sealant is just extra protection for when you do eventually get a puncture later.
Thanks for all of your suggestions. I think I have figured the mounting of the tires out. Replaced my rear tire yesterday and decided to inflate the tire first so that the bead seated in the rim of the wheel. I then deflated the tire and removed about a 6 inch section of the tire off of the wheel. Used a syringe (as suggested above) to get sealant in the wheel/tire and then re-inflated the tire. A little bit of the sealant came out but otherwise got the whole thing down to less than 10 minutes with a lot more successful conclusion. By the way I must say I love the tubeless tires and will probably never go back to regular clinchers. I have been suffering with back issues for years and never enjoyed riding more than 60 kms. This year I am doing 100 plus km rides with no back issues and I think a lot of it has to do with the dampening effect these tires have.
I just got my tubless wheels and fusion 3 tires. I tried the hanging method of putting the sealent in with a little of the lip of 1 side of the tire hanging out and pouring the sealent so it runs down the bottom. Thats all fine and said however the biggest problem is getting the new tire onto the wheel. You will be struggling really hard to do this. Meanwhile you'll be shaking the tire around and the sealent at the bottom will seep out of any small tiny opening since this method has you putting the sealent in before the beed fullly rests itself to the side of the wheel.
Its quite messy. Instead I went and got the removable core valves from Stan which is a much much cleaner process since before you even inject the sealent, you have to first inflate the tire so the beed firmly rests against the wheel and then you deflate once you've achomplished that. A hell of alot better process.
Anyway from all the videos I've seen of this stuff... all the puncturing and virtually no air escaped. He even had a video of his MTB running over a floor of nails about 20 times and it still retained air.
With this stuff I see no reason to carry am extra tube. Maybe just 1 cartridge of C02, but that's it just so you can stay at a high psi.
Odd, I haven't had that issue; I fully mount the tire (never been too hard) and inflate it. Of course on some rims it's air-leaky, but not so much that I can't pump it up to 140 lbs and make sure it's generally seated and ok. I can hear the air hissing from the rim seam (if there is one) sometimes.
Then I deflate, hang, push the bead in a bit, inject Stan's next to the bead, let go of the bead, and immediately inflate to the usual 90-100 lbs. Sometimes a little sealant comes out, but not much.
You still need to carry a tube on long rides. Two mornings ago I ran over a piece of metal that *shredded* the tire. That one didn't have more than about 1500 k's on it; what a waste. Fortunately we were almost done with the ride, so one of the other guys went and got his truck and gave me a ride. Had we not been close to the end, I would have had to boot it and put in a tube. No other way to fix.
PMT that is the method I am now using and it works to a T. I think the problem is that the Stan's video is confusing the issue for those with Tubeless tires instead of the kits. I think what happened to me is that by attempting to put the Stan's in the tire and then inflating the wheel is that the crystals get stuck in the bead and make inflating it near impossible. The trick as you say is to inflate, seat the bead, deflate, pour in the Stan's and then reinflate. Don't think the 2 piece stems are required.
Sorry to hear about your tire, just happened to me too.
Wiggle (landed, no postage) 2 tires for $105 canadian.
How exactly would you be able to push the beed in a little on a road bike 23mm when there barley is any room to pour in the liquid? I can see if you are using a thin injector of some sort, but still If your injecting it by pushing the beed in after you've deflated the tire then the liquid has a high chance of going in between the beed and wheel instead of going rolling through the inside the tire. If that happens then you're not getting the full amount of the required liquid within the tire.
Besides 2 Valves and an injector is $40 shipped. That's far from breaking the bank.
Then again, if you still have to carry around a tube because there is still a chance of getting a flat then why even use this sealant? According to the videos shown demonstrating how this stuff works on road tires, he was puncturing it with a pins over and over. It still held air.
http://www.youtube.com/watch?v=KU5hR-suxQU&feature=related
"In the last 24 hours we lost less than 10psi in this tire with over 25 punctures"
I'm actually using the Fusion 3
You just use a plastic syringe. I can push the bead in and see the Stan's yellow tape, so I aim it right there and inject. Easy as pie. There's plenty of room to squeeze the 23mm tire.
The point of carrying a tube is for a drastic emergency, like a serious tire cut. Minor punctures get sealed by sealant so you don't even necessarily have to stop.
I have four sets of different wheels with Stan's conversions and Road Tubeless, and easily over ten thousand kilometers, so I probably have a good idea of how it works. Maybe not though; perhaps someone with fifteen thousand k's on Road Tubeless would like to correct me.
I think Stan's does themselves a disservice in explaining how to put these tires on because once you figure it out it is quite simple. No need for the 2 piece presta valve or tape if you are running a tubeless wheel to begin with but they don't explain that very well. I learned more from the posters in this thread then from Stan's. Stan's has a forum on their website as well and it would appear from other comments that if you can install these without their stems and tape (if you are running tubeless wheels) then you are probably better off as some experienced problems with air escaping near the valve.
The people that are leaking air at the valve probably did not have it seated properly and probably did not have the nut tightened fully. In addition the Mavic type UST valve requires a small rubber O ring which people probably forget to install thus causing leaks. You don't "have" to use the 2 piece valve (with the removeable core), but it allows installing sealant while the tire remains seated on the rim once installed. For that matter, you can make your own stem from an old tube and just install it yourself. You just cut it to size. You don't have to buy the $10 Stans "tubeless" valve stem.
This really is not hard. I just got some Ultegra 6700 wheels and Hutchinson Atom tubeless tires. I went thru a learning curve getting them seated the first time and rode them w/o sealant w/o problems for a few weeks. I had a 100K charity ride so right before the ride I just deflated my tires (my 6700 wheels did not come with vales with removable cores?) and used my tire lever to unseat a few inches of the bead outside the rim. The Stan's Sealant bottle comes with a cone shaped lid with a red cap. I cut the end of the cone shape lid off and squirted plenty of Stan's in the tire. The I just used the tire levers to put the bead back in the rim and aired them up. It took about 5-10 minutes for both front and rear. No big deal.
I had a tire with a slow leak last weekend. The sealant was a couple of weeks old and kind of dry (and I only used half the amount recommended).
I patched the tire and it took air. The tire inflated up nicely on Saturday. By the time I went back on Monday morning, the tire was totally flat.
Not sure if the tire is still leaking or if the the sidewalls did not seal up really well. I did not clean out the dry sealant that well. Debating whether I should try and reinstall the tire using new sealant and hope for the best? I have tubeless wheels so a new tire properly installed will inflate without the need for sealant.
Yeah, you might make sure it's all cleaned out well, remount/reseal, over-inflate (140-180) and then check in water to find if there's a leak or not.
I use a wallpaper tray to do the water check, since it's long and skinny.
When you put the new sealant in, hold the wheel horizontally and shake it around as you turn it to make sure the sealant gets all the way around.
And on a related subject, I just did a 200k on a new Fusion3; couldn't tell any difference from the Fusion2. Check back with me in 6000k and we'll see if it wears any differently.
over 3K on tubeless and here are my thoughts
Fusion 3 is a tougher tire and less prone to slits vice fusion2 - the two is little better when it is wet
i prefer caffee latex - i understand it does not have any ammonia in it and rims look fine
you should probably clean out your tire/rim every 3-4 months as it will dry up some
caffee latex has an inejector and you can squirt it in via a regular presta valve
so mount the tire, inflate to 120 psi and get it seated, then deflate, and inject the liquid through the valve, and reinflate
i usually use 25ml instead of the 50 ml
if you get a hole, the best thing is to keep riding - i have had numerous holes but only had one hole with the sealant where i had to stop
it took me awhile to realize that on some of my longer rides that my rear wheel got mushy because i lost some air while the leak was getting plugged.
if the tire goes flat just put a tube in it and keep riding
If you get a flat often a bumpy 'scab' will form on the outside, don't pick it off, unless you are prepared to ride around to get it to seal again
it is fairly easy to seal the hole long term with a patch inside
i don't even bother with water and soap when sealing up the tire - the fusion 3's seem easier to mount
the hardest part is making sure the tire is seated around the valve, i can rememer spending 30 minutes once trying to mount it and using a compressor before i released i just didn't get the tire down around the valve
i know it says don't use them, but i have to use a plastic tire iron to install and remove
hutchinson offers a special tire iron that is wider and has this sponge with a soap/water reservoir but i just use my 20 year old plastic nashbar ones
personally i really like tubeless - no snake bites, a little softer ride with lower pressure, much fewer tire changes
Interesting read. Surprised to hear about your preference for the Caffee Sealant as it got a horrible review in this month's Mountain Bike Action (Sept) magazine. But each to their own and glad to hear you like the tubeless!
21 - 40 of 43 Posts
