1 - 20 of 22 Posts
...to any body running tubulars, what tire pressure are you putting in and what would you use for a little more comfort? I recently purchased a set tubular wheels, glued them up and put them to 155psi, and my a$$ took more pounding than a catholic school boy. with my clinchers i run 115 and i dont feel the way i did when i got off my bike this week. any comments would be nice, thanks :D
Does you rims have a max. pressure? My carbon tubie rims max. out at 125 psi. and that's what I run in them. At that pressure, they ride SOOOO much better than my aluminum clinchers at 120 psi.
What???!!!
Why on earth would you pump them up to 155 psi? That's for racing on the track. Tubulars run at the same, or perhaps lower pressure than clinchers. The general guidance for a good balance of comfort, traction, and rolling resistance (for tubulars or clinchers) is 90-100 psi on the front, 100-110 psi on the back. If you want more comfort, lower the pressure. Raising the pressure will not gain you anything, because the higher pressure tire will bounce off of road imperfections, slowing you down.
G
155 is a good way to rattle your fillings loose.
100 psi, maybe 110 and you are fine.
thanks for the replies, i will put them down to what i have my clinchers, thats what i was going to try anyway, but others with tubulars are nice to hear from.
I'm 168lbs and I like to run the Vittoria EVO CX's in 21mm at 115 rear 110 front. I've experimented with more and less pressure, for me, this seems to be about the best.
Administrator
100-110psi at 176 pounds
Does a lower pressure increase your chance of rolling a tubular off the rim? Would it be worth it for a crit to run a little higher like 130?
'brifter' is f'ing stupid
a 'little' higher? that's a ton higher. if cx racers don't roll tubulars at 25psi, road riders won't roll them at 90-100.
Take me higher
If we're ever racing against each other, I would recommend that YOU pump them up as high as you can. That will give ME a significant advantage when cornering, and if the race is long or on rough surfaces, I'll be a lot fresher at the finish. Works for me! :)
No Crybabies
120
I run almost all my road tires at 120 psi. Exceptions are one of my commuters, which has 35 mm tires, I run at 100, and when I do climbing time trials, when I'll run them around 150, as my speeds are around 5-10 mph and there is lots of standing. I'm 160-170 pounds (varies).
I did in my stupider years try running some Tufo tubulars on narrow, light carbon rims for a 155 mile, 13,500' climbing event at near max pressure, like 180 psi. Beat the hell out of me and nearly felt like ice in the turns, by they did feel good on the climbs. Never did it again.
120 is still high for tubulars. why ruin the ride quality and have more rolling resistance when you can safely drop 20 (or more) psi and really enjoy the ride? if i had 35mm tires, i'd be down around 80psi...
150 for climbing? you're still on 'roads', which aren't (even if they seem like it) perfectly smooth. you'd go faster w/ lower pressure, and as you've found out previously...you'd have better cornering traction.
No Crybabies
standing?
When I'm standing a lot on a hard climb, harder tires seem to feel less "mushy" feeling. It feels like less energy is being wasted. Cornering on a climb is pretty irrelevant -- we're talking 5-10 mph here.
I like a more confident feeling from the tires pumped to 120. Lower, they feel less predictable. I don't notice any loss of traction like you might find at 150 or more.
A lot of this is "feel," and maybe not so scientific.
By the way, Zipp recommends about 120 (for 150 lb + riders) for its Tangent clinchers, which I use for time trialing, and about 5 psi more for tubulars, with slightly less for rough roads or rain.
http://www.zipp.com/accessories/detail.php?ID=72
http://www.zipp.com/accessories/detail.php?ID=51
I run tubulars and 700x25 clinchers at 6bar-front/7bar-rear and 700x23 clinchers at 7 and 8 to avoid pinch flats. I'm 180lbs. I only run my tubulars at 120-130 on the track or for TTs. Just seems silly to put more air in that that and more than that is just needlessly reducing contact patch in my opinion.
the tangent has a pretty unique profile and may need a bit more pressure to maintain that shape. i will say that those tires (the tubular) go on really straight...it's every easy to mount them pretty much perfectly. i haven't spent much time riding on them, but they seem nice.
i weigh about 155-160 and use to ride tubulars around 120, like you. over the last few years, i've gone progressively lower on the pressure. i'm convinced that the lower pressure works best on real world roads...uphill, downhill, cornering, whatever. they don't feel mushy at all to me, but then i run my cx tubulars regularly at 25-27psi.
1 - 20 of 22 Posts
