1 - 9 of 9 Posts
I just bought a set of Zipp wheels (303 front, 404 rear) that came with Tufo 19mm tubulars. I rode them on Sat (120psi) and the ride seemed more rigid/rough than usual.
Thinking about switching to a 22mm tubular, however wanted some perspective on the advantages/disadvantages of running a 19mm tire. These tires seem tiny to me.
Thanks.
G
Thanks.
Here is my input.
No-one in their right mind would ride 19 mm tires under any circumstances unless they really want to part company with their fillings.
Banned forever.....or not
They might be OK for a TT tire if you bomb them up to 150 psi. After 40K, fillings may begin to fall out.
I'll pulled the Tufos off last night and put on some Conti's that I hadn't yet glued on my 404's. The Tufos will make for a great spare as they fold up much more compact that the Conti's do. The Tufo Tape that was used was a complete mess. I'll stick with glue. I followed the gluing instructions found on YouTube using a medicine seringe from Walgreens and warming the glue with hot water. This worked out fantastic. The least mess I have had to date. And the rubber gloves were key. No pealing glue off the hands.
Itspat
I'd be curious to hear your comments if you do decide to go with a different set of tires.....I run a Tufo Carbon rear and a Vittoria EVO CX on the front wheel, and all I read is how poorly the Tufo's ride in comparison to other tubulars.
BTW I run the Tufo rear because it's what came on the rear wheel (it was brand new) whereas the front wheel needed a tire (so I went Vittoria).
1 - 9 of 9 Posts
