1 - 20 of 30 Posts
Escorted from the White House
Don't know if the following info is legit, but, FWIW:
(though it would make sense for Shimano to leak some info, in light of SRAM's recent big announcements)
Discussion Starter · #2 ·
Also, this write-up, which I assume was either a) released prematurely and then yanked (this is from a cached web page), or b) is simply someone's idea of a hoax.
Shimano Launch New 11-Speed Ultegra
Triathlon Plus|Gear|Gear News| 25/04/2013 09:53am
Shimano incorporates 11-speed to Ultegra
Today SHIMANO launches its 2014 Ultegra lineup. The new 6800 series incorporates race proven Dura-Ace technologies to improve comfort and control, like an 11-speed rider tuned drivetrain, improved shifting performance and more braking power. Both groupsets share their true spirit of the sport. Where Dura-Ace focuses fully on professional race level, Ultegra brings race proven technology to cycling enthusiasts.
The dual control shifters give tactile feedback to the rider that the gear shift has been completed. With a shorter lever stroke and defined click engagement the shift is completed. The hoods and bracket grip are more compact, and the carbon lever has been redesigned to improve ergonomics and control.
Both derailleurs have also been completely redesigned. They are more compact, lighter, feature a shorter stroke at the lever and deliver more even shifting effort throughout the full range of the cassette. The new drivetrain makes shifting and braking as easy as possible so a rider can, concentrate on the ride, especially in tough conditions.
The new Ultegra 6800 series has 10% more braking power that its predecessor. The extra brake power results in enhanced control, especially from the hood position. This, in large, is as a result of the new symmetrical dual pivot design and the new brake shoe compound. Besides increased braking power, modulation is improved by using new polymer-coated BC-R680 cables. The Ultegra brakes are also available in a direct mount version for aerodynamics (BR-R6800).
Ultegra 6800 has a rider-tuned drivetrain. Rider-tuned means that riders can individually choose a large variety of gearing options for all kinds of riding, whether you ride races, Gran Fondo’s, sportives or cyclocross. The Ultegra cassette is going 11-speed. From 11-23T all the way to 11-32T. The Ultegra 6800 crank shares the same 4 arm design as its Dura-Ace counterpart. The 4 arms provide a better power transfer compared to a five arm design, and reduce overall weight. The crank is available in 53x39T, 52x36T, 50x34T and 46x36T.
The chain (CN-6800) with a new surface technology called Sil-tec. an advanced surface plating technology to increase performance. Recently debuted in the Dura-Ace 9000 chain, Sil-Tec technology adds a low friction surface treatment that runs smoother and lasts longer.
With Ultegra going 11-speed SHIMANO has developed an 11-speed wheel on Ultegra level, the WH-6800. This lightweight wheel has a wide flange hub and an offset rim for high rigidity and power transmission. It has a digital adjustment system and less quick release axial force for easy maintenance and cup & cone bearings for durability.
Compatible in tubular, tube and tubeless. As with all SHIMANO wheels, the WH-6800 is 100% in-house produced and hand-assembled.
Read more: Shimano Launch New 11-Speed Ultegra - Triathlon Plus | TriRadar.comhttp://www.triradar.com/gear/shimano-launch-new-11-speed-ultegra/#ixzz2RkeHTFd6
Discussion Starter · #8 ·
Discussion Starter · #9 ·
I need to pick up some 10 speed Di2 soon then. I have too many rear wheels to switch over to 11sp anytime soon or maybe even ever.
Discussion Starter · #12 ·
Discussion Starter · #14 · (Edited)
From the cyclinside article, yes (hence why the'yre referred to as 6800), but the components on the Shimano promo frame are definitely Di2.
Agree on that as well.
Ppl who are focused on either the mech or the electric can probably rest easy, as you'd think Shimano is going to release both for the new Ultegra (though maybe not exactly at the same time?, i.e. they'd likely announce both at the same time, but the actual release dates for the two could be somewhat different).
Shimano is making some updates to their wheels and pedals for 2014 and have a tentative release date for some of that in September. I imagine mfg for 6800/6870 would be in full swing not long after that in order for it to be OEM on the 2014 round of bikes. It always seems to take longer to get a hold of new group kits by themselves than it does buying it on complete bike. We'll see how long it takes to get SRAM 22, for instance.
Blah,
That frame looks like some crappy chinese open mold get up.
LOL ... don't know your frames do you? It's a repainted Scott Foil, not a Chinese knock off. Might want to actually look at the frame before dissing it.
As for Shimano Ultegra ... all I can say is Blah! Di2 Ultegra is better, but the cable stuff, just not interesting, heavy and expensive compared to SRAM components.
1 - 20 of 30 Posts
