1 - 2 of 2 Posts
Greetings All: I just bought some used 685 hydraulic Ultegra shifters. The right shifter is missing the handlebar clamp and hardware. Can I use the clamp and hardware from my 105 mechanical shifter? Thanks for your time and consideration.
What you probably bought are a pair of Ultegra RS685 levers for hydraulic disc brakes. You're in for an interesting conversion project if you plan to create hydraulic shifters. Shifting is either done mechanically or electrically, but not hydraulically.
If you're wondering whether the levers can be attached to your bars with the hardware holding your present brake/shifting levers in place, why not try it?
1 - 2 of 2 Posts
