1 - 3 of 3 Posts
Internets User
So my bike has Ultegra SL and I recently replaced the rings, chain and cassette (12-27). I just replaced all the cables which made no difference with the issue. In the big ring it shifts perfect but not in the small ring. I can adjust the cable and fix it but then the shifting suffers in the big ring. What is going on here? I suspect the rear derailleur may be suspect. Chain line looks good. Chain length might be a tad long but only by a link if that.
Chain is too long only if it droops or rubs on the underside of the rear derailleur cage when in the small-small combination.
First guess would be a derailleur hanger that is not perfectly aligned.
Internets User
Thanks, it does droop a tiny bit in small small. Would be surprised if that is the issue but I can easily take out a link with out worrying. The hanger is a possibility but its not obvious looking at it.
1 - 3 of 3 Posts
