Brake movement?
teffisk said:
I was just changing a tire on my back Helium wheel so I took it off, (just as Ive done many times before) and when I put it back on it wont spin straight for the life on me! I tried loosening it and retightening it like I usually do when this happens but no matter what I do, I always see the rim off set and rubbing the brakes :mad2: . I know this makes me sound retarded, but Ive never had an untrue wheel so I was wondering if this is it.
If I understand this correctly, you are saying that the rim rubs the brakes, not that it has a wobble. The most likely explanation is that the brakes were knocked off center, causing them to rub. If you flip the wheel around (put the cogs on the left side) and the rim rubs on the same side, then it is the brake that is off center. If you were able to knock the brake off center when removing the wheel, then you likely can center it again just by pushing on in by hand. Once you have recentered the brake, operate it a few times to be sure that you have actually centered it, not just pushed it around. Also, be sure the bike is sitting on the ground when you open and close the quck release so that it is fully seated in the frame.
For your reference, most people would say that a wheel is out of true when it has either a side to side wobble or an up and down hop. A wheel that is not centered properly is considered to be "dished" wrong. Flipping the wheel (front or rear) will tell you if it is properly dished.
