1 - 2 of 2 Posts
· Downhill Juggernaut
Ok, I've been running my homemade light that I shamelessly copied from this thread here: http://forums.roadbikereview.com/showthread.php?t=57384
I started with the SLA battery, but found it too heavy and bulky to use regularly. I then found this battery: https://www.batteryspace.com/index.asp?PageAction=VIEWPROD&ProdID=2193
I found it on e-bay for $49.99 and got it last week ( http://cgi.ebay.com/ws/eBayISAPI.dll?ViewItem&rd=1&item=7142026725&ssPageName=STRK:MEWA:IT ). It works great. The NiMh really works well. I did a test run on it and got a little over 3 hours off a single charge. This was with the 20 Watt light. It is a truly incredible light. The PVC doesn't overheat (although it does get warm) and it lights up the entire world in front of me. Total cost on this light, around $60.00 or so. Not bad for a 12V 20 Watt light. Probably could have made it even cheaper had I not been so impatient and bought more online instead of purchasing stuff locally.
Thanks to Croswell1 for posting the how-to on this light!
· "Cypress Gardens" Fl.
Thank you....thank you very much...........
Glad you got some benefit from my thread, Chris. You are right about the SLA battery though, it is a little heavy but it sure is cheap. I would also like to get a nimh water bottle battery too, but other bike parts I need get in the way.
1 - 2 of 2 Posts
