1 - 2 of 2 Posts
Been riding for a year on an old Cross bike. Weighs in at 25lbs. I think it's time to upgrade to a real road bike.
I'm looking at endurance frames for comfort. Some of the roads I ride are quite cracked so I'm looking at a Trek Domane.
Climbing is my nemesis. For example a 4% grade over 1.8 miles my average speed is 10mph. On strava it seems like other guys are pushing 14mph.
My budget is $2k though the lower the better as I'd like to buy a nicer wheelset. I'm not opposed to used either. I think I want to stick with disc because you can fit larger tires. I currently ride 37-622 which is 35c tires. That's about as small as I want to go. 23 and even 28c tires seem to produce a jarring ride.
Or perhaps I should upgrade my cross bike instead to make it faster? I probably won't get the comfort but if I can hang with other riders and not get smoked then it might make the ride more enjoyable. I'm sure I could probably drop a pound by going with a better wheelset. Current ones use a disc hub with a rim brake rim and some City Ride 2 tires.
If you could shave 10 lbs off the bike, your climbing speed would increase about 1 mph. If you want to get to 14 mph, you need a bigger motor or to lose 40 lbs from the bike and body while keeping power output constant.
It is possible to use brakes other than discs that allow wide tires.
1 - 2 of 2 Posts
