1 - 9 of 9 Posts
See pictures below. My two questions are:
1) See how close the cadence magnet is to the pickup (I've added a third, clearer picture, below). It was NEVER that close b/f. I started noticing a knocking on that side of the crank the other day, and this morning was the first time I had a chance to get up close and personal. It kinda looks like the crank arm is bent a bit. Thoughts???
2.) There is no bolt in the lower right bolt hole. Is it supposed to be that way, or is it missing????
Do you seriously think a crank bolt SHOULD be missing? Of course, it's fallen out.
The way to check for a bent crankarm is rotate the arm so it's parallel to the down tube and measure the distance from the side of the down tube to one edge of the crankarm. A difference of 1-3mm would be common, but not much more.
I assumed that on the crank bolt, but just wanted to make sure. Plus, I had a big night last night and brain was a little fuzzy.
Regarding measuring for a bend, do you mean measure from two different spots, and if the variance is greater than 3mm, something is likely amiss?
Is the crank arm bent or loose?
Also, is the crankset octalink? I ask cause I just wrecked my 105 crankset and bottom bracket by not having the splines lined up correctly. While my crankbolts didn't fall out, I started getting this terrible creaking noise. Took it to the shop, they diagosed the problem I described above. Ended up that I had to buy a new crankset.:mad: although it gave me an reason to buy on NOS Record crankset that I had my eyes on
Is it possible that your cranset is now twisted on the bb spindle and that is why it looks bent?
Good luck,
If the crank arm were bent, I think you would feel the pedal osculating around while riding. If you're not sure or think you might have become used to it, have someone else test ride the bike - as most people can feel the most minor bend in a crank arm/pedal axle.
I'm not familiar with your specific crankset model, but it seems odd for what appears to be a standard BB to have no visible axle showing between the face of the BB shell and the crank arm. There might be a chance your cartridge BB has shifted to the drive side, or your non-drive side crank arm has crept up the BB taper too far.
Discussion Starter · #8 ·
I had the bolt put in at the LBS this a.m. I then when for a 2 hour ride and all problems were solved! Doesn't explain the closeness of the pickup to the magnet, but I think it is all good.
1 - 9 of 9 Posts
