A middle aged man riding a standard 53/39, with 11-23 in back, asked for a new gear cluster at the LBS. He never uses the 11 or 12, but could use some lower gears, so wants a 13-26 or 13-27 to work with his Ultegra drivetrain. Well, a quick search determines that Campy is the only one offering a 13-26. All of the Shimano and Sram clusters available in US outlets start with a 12 or 11.
If only hard core racers use their 11 and 12s, why aren't 13 and even 14t. clusters more available? Most riders would be great with 14-27, but I found only one cluster with that range, a mid-level Campy 10 speed, 14-23 straight block, probably aimed at junior racers.
One of the guys at the LBS said "Get a compact crank, say 48/36." Is this the reason for compact cranks? So average guys can use their tallest gears?
Then I was thinking about how there's noticeably less rolling resistance with big cogs front and back, than with small cogs at the same road speed, because the larger cogs aren't spinning quite as fast, and the chain tension is being distributed over more teeth. This means the chain and the freewheel sprockets will last longer, and argues against compact cranks.
What are your thoughts on this?
1) Why aren't 13-27 or 14-27 clusters available and spec'd on roadbikes?
2) Are compact cranks a good way around this problem?
3) What would be your ideal gears, front and back, ones that you would use a significant proportion of the time?
