So this is actually a couple of questions in one.
First and foremost...is there a difference between ultegra shifters for a double v. a triple? If not is there anything you have to do to "set" it for double v. triple?
Now the problem:
I've just installed ultegra shifters on my bike (double). When in the larger chainring I start getting a cross chain noise when I'm in the 5th cog. According to Lennard Zinn I should be able to "feather" the derailer by shifting the lever until I hear a "soft click." The problem is that I have no such "soft click." Either that or my "soft" click is actually really loud and definitely shifts the chain.
I can "feather" using the "soft click" when I'm in the smaller chainring going towards the smaller cogs.
Zinn says that you can't feather a triple. Is that because the feathering mechanism is adjusted to be used for shifting instead or is that because the feathering mechanism IS the shifting.
Thanks for any info.
_42
Now the problem:
_42
