1 - 7 of 7 Posts
I just got my first cyclocross bike, a sweet little LeMond Poprad. It, like most cyclocross bikes I've seen, came with canti brakes. I'm a bigger fellow, so on my first few rides I was definitely missing the stopping power of discs or v brakes. Now I've had some adjustment issues and a stripped tensioning screw, so I am going to have to replace or repair the front brakes at least. I am thinking about just installing some v brakes instead (front and rear). Is the some reason why you don't typically see V's on cross bikes? Weight only? I would gladly sacrifice a few grams for the added stopping power. Any thoughts/adivce is appreciated.
Number 2 on the course.
They don't offer as much mud clearance. They require the pads to be run closer to the rim. They require a different amount of cable pull, and thus require adapters (Travel Agents) to work with standard levers. Travel Agents come with another list of downsides. There are V-brake specific drop bar levers available, but not with integrated shifters.
NeoRetroGrouch
The answers you will get:
- You just don't know how to adjust them
- Racing: you don't need to stop, just scrub off some speed.
- You ever seen V-brakes on the CX bikes in Belgium?
- etc.
My experience: I also weigh a lot and do not race. I've tried cantis, Vs with Travel Agent and mini-Vs. All about the same. Work OK for a fast run on the local trails as long as nothing requires you to stop. If you come around a blind corner and find a 3-wide group of cyclists discussing politics, be prepared for a little off-trail excursion through the trees. On a wet day at an intersection with a truck running the red light - your dead. The only way to stop is with discs. YMMV.
TF
EDIT: Forgot the mud thing. Also remember: cyclocross= racing only. - TF
Well, since we can't just 'ride cyclocross' anymore, you are more than welcome to join me in psycho-cross....it pretty much picks up where the roadie types leave off...it encorporates anything FUN that can be done on an 'road style' off-road bike, ie29er w/ dropbars. I've found that V's or disc are pretty darn helpfull. If you set them up right, v's are as good as the $$$ avid mech. disc brakes w/ the exception of water crossings, very small rocks embed in the rim pads.
If you have v's and can't stop on a wet road any better than sidepulls, get a new mechanic, stopping on a decsent setup is determined by the slippery asphault, not the brakes.
Best bet is to have a mechanic who uses them, AND recommends them, install them for you. If not, it is a bit of a learning curve. ALWAYS use the adjustable travel agent...I can give you some install tips if you want.
*if your frame is flexy, the v's may spread the stays/fork, a brake arch will fix this.
Same boat so i switched and love em. I am not a euro pro racing in world cups so i am not terribly worried. When I weigh less I can always switch back. These allow me to come harder into sections and brake later. YeahI need so much more practice, but for now it makes me better.
Avid SD7s and Drop-V levers
I'm an OFB and I'm delighted with my most recent commuter/cross setup - Avid SD7s, kool stop pads & Cane Creek Drop-V levers. I was considering going with discs but now I don't think I'll bother.
Or you can just do this..
Chop, Chop V-brakes
Much more leverage than standard canti's, straight contact in between the rim and the pads do to the parallelogram for "Rim crunching" brake power as oppose to a arch (not such a big deal) and they work just fine with road bike levers.
Then again the Paul canti's work equally well if not better and you bike will look Pimp as hell.
1 - 7 of 7 Posts
