Sorry, no luck searching...
I use a Park framepump. Every now and then when inflating the first "push" seems to take a little extra effort like maybe the valve is a little stuck but once the tube takes that first push of air, it inflates no problem. This would happen very infrequently until now. I have no problems inflating the front tire but now all the sudden the rear tire, every time its low, it's like wrestling with a gorilla trying to get that first push of air to go through. I'll take the pump off and reseat it again but still no luck. Eventually, and i'm not sure why, i'll hear a little click and then the tube will take air no problem.
I'm thinking there's some kind a "airlock" maybe in the valve-I have no idea how these things are put together but it's like something is stuck or a "flap" won't open. I'll take my pump off and use my finger to release a little air to try to "free up" something or other but that doesn't work either. Now, maybe this could be a factor: the lock nut when it's fully unscrewed (opening the valve) points rather crookedly. This was done by me when learning to use a pump by trying to "rip" the pump off with both hands rather than pushing the pump away from the valve with my fingers. Maybe since that locknut is crooked, somehow the pump after it's seated isn't able to force the valve open.
Well, i'm def attributing it to a faulty valve since I'm having no problems when I inflate the front tire. So when it p's me off enough, I'll just replace with another tube.
Anybody got any ideas? Have pity on a noob:cryin:
