1 - 1 of 1 Posts
Hi,
I have the Venge pro with Ultegra electronic shifting, sram red crank and chain rings.
My bike is making a rattling noise, especailly on chip sealed roads.
I don't think it is my valve stems or saddle bag.
I think it is coming from the chain and chain rings as it makes a similar noise when I lift up the front end a couple inches and drop it back down while holding the bike in the garage.
Anyone else had this excessive rattle noise vibrate thru the frame?
Should I try different rings and chain mounted on the SRAM crank arms?
I have the standard 53x39 130mm spacing.
If so what brands do you suggest.
Thanks
1 - 1 of 1 Posts
