1 - 4 of 4 Posts
I am a 31 y/o who is 5'4 1/2, 145 lb who wants advice to be fitted on a 585. Most likely will need a 49, just making sure a 49 would be ok since it is the smallest frame. I looked through the LOOK forum and most people are a little taller than me, so hard to compare.
Here is my measurements, my pops and I did the competitive cyclist fit calculator.
INSEAM: 28.25 INCHES
TRUNK: 22.25
FOREARM: 12.5
ARM: 24.375
THIGH: 23.375
LOWER LEG: 19.875
STERNAL NOTCH: 52.75
BODY HEIGHT: 64.5
Don't know if that is to much info or not. Per the fit calculator, I would need a Top Tube of 52 on a BMC Team Machine. The 49 LOOK frame has a 52 top tube.
Thanks
My best advice would be to ride the bike. Go to a store that's my best advice. Even if people tell you what you should fit, it wouldn't matter. The best fit by standard might not be the best fit for you.
couldn't ride any larger...
If your inseam is an accurate cycling inseam, to saddle-like crotch contact in bare feet, then the standover height on the 49cm frame, at 71.7cm is identical to your inseam. Only your shoes will provide any standover clearance.
Thanks guys for your words of wisdom. C-40, looks like that would be the right size. There is only one dealership that sells Look in St. Louis and they have a size 53. The ride was great. I did not want to talk to many specifics with the dealership since I will not be buying the frame from them, instead online, better deal. At that shop I rode a Scott CR1 and cannonadale six-13 but the Look one.
Now that the frame has been decided on, next is the wheels. I have been doing a lot of research on this forum, sounds like I need to test ride a few of the wheelsets and go from there. Everyone has their favorites.
Todd
1 - 4 of 4 Posts
