There's something elegant in stainless steel cables, cinched down with an 8 mm allen wrench. Back before click shifting, a sprinter would slam the shifter all the way forward into the last gear and stomp on the pedals. No click stops, thank you. If the chain wasn't in gear, rider would tighten down the wing nut on the shift lever and manually adjust. Putting clicks in there was in a sense going backwards, turning a manual function over to mechanical, thereby taking away control when the derailleur cage gets bent out of whack. Those long derailleurs on 1x are hanging down just asking for it.
That's ok, though. Modern enthusiasts have to go with modern tech. Computer shifting is the current hipness, like watt meters, really low gears, proprietary shoe-pedal combos, hydraulic disc brakes, thru axle wheels, one piece carbon stem-handlebars with the i phone sticking out in front, and carbon fiber frames. There's no longer manual over ride when thing aren't working on that freedom machine. But WTH, you can always call home!
