1 - 20 of 27 Posts
You hear the words "lightweight wheels" a lot, but just curious as to what weight range would you consider a set of wheels lightweight or "climbing" wheels?
From what I've gathered:
super lightweight : < 1200 g ?
lightweight : 1200-1400 g ?
moderately lightweight : 1400-1600 ?
not lightweight : > 1600 g ?
Not trying to start another what makes a wheelset a "climbing" wheelset thread, but just wondering what weights you have in mind when saying that a wheelset is "lightweight".
Thank you.
About what you said, assuming you're talking about clinchers.
Yes, thinking about clinchers mostly. But would those ranges change much if we included tubulars also? I see what you are thinking though...as 1500 g tubulars would likely be considered somewhat heavy rather than light.
Think a lot of it depends on your weight and intended use, 1600 grams could be considered lightweight for someone that puts down a lot of power and weighs 210 pounds racing crits.
Banned Sock Puppet
What is the definition of "lightweight"? Anything deemed so in the marketingland of any particular manufacturer.
Thank you.
These seem roughly right to me.
But does someone actually make or build a sub 1200g clincher?
Banned Sock Puppet
Banned Sock Puppet
Discussion Starter · #10 ·
Point taken. There are definitely a lot of variables/situations and my original question definitely leaves room for interpretation.
I am primarily referring to "lightweight" wheels in reference to climbing.
Discussion Starter · #11 ·
At the risk of going slightly off topic, I posted this thread to also get an idea at what weight difference would one set of wheels be noticeably better while climbing versus another (say 30 miles with 5000' of elevation...my typical routes)? By "better", I mean less effort/less fatigued at the end and more responsive when out of the saddle for short periods. Again I realize there are other factors involved (wheel flex, rider weight, rider's ability, etc...), but just looking at noticeable weight difference here.
200 g difference? Likely not.
300 g difference? Probably not?
400-500 g difference? Likely will notice?
>500 g difference? Definitely will notice?
On a personal note, I've been riding mostly tubulars weighing between 1150-1350 g (different sets) and now considering a set of Carbon Clinchers...just for those remote rides where a flat with tubulars would really su*#. The clinchers would likely run about 1400-1450 g. So going from the 1150 set to the 1450 set...that's 300g give or take. I haven't purchased the clinchers yet, but seriously considering them....Knights 35 carbon clinchers with Aivee hubs (just FYI).
Most custom builders are smart enough not to but there are hubs/rims/spokes out there that make it possible.
To be clear, I have no interest in a wheel that light, and I'm not a heavy rider. I was just curious. It seems to me that sub 1200g is really hard to get to. For example:
Kinlin XR200 rims, around 775g for a pair
Novatec or Bitex lightweight hubs, around 300g for a pair
Sapim Laser or CX Ray spokes, around around 200g for 44 spokes.
Once you add some grease for threads and oil for nipples we are going to be close to 1300g, and that is a 20/24 build with a superlight rim. BHS doesn't even sell this rim in a 16 drilling, so I don't see how you go lighter.
Seems we would need to start with a rim that weighs only a bit over 300g, and I'm not familiar with any clincher rims in that weight. I'm sure I'm missing some that are, but I bet those would be old school rims that should be built with a TON more spokes.
Overall, I feel like 1300-1350 grams is about the lightest you can go for a clincher.
Discussion Starter · #13 ·
T
Yeah, from what I've researched, that seems about right for a good set of "light" clinchers...whether carbon or aluminum.
What's with all the guessing? You can directly calculate these things. Go to analyticcycling.com
For reference: 150 lb rider, 6% grade, 250 watts, saving 1 lb. (454 gm) increases speed by 0.1 mph. That's 34 seconds per hour of climbing, or 550 feet. That's how much you would be ahead of an identical rider carrying the extra 450 gm.
Banned Sock Puppet
Woohoo! 450 extra grams! No wonder I've been falling behind 34 seconds per hour! I gotta get some ultra-light wheels now! :lol:
Discussion Starter · #16 ·
What is considered &quot;lightweight' wheels?
Thanks Kerry. Pretty interesting seeing those stats! I would think that that 34 secs would increase per hour of constant climbing, no? As the extra weight, albeit not that significant, would take a cumulative effect on the time disparity.
is riding in MOPP4
We also need to consider where that extra pound is located. I think that one would notice the extra weight more if it were in the wheel set as opposed to a heavier frame?
Discussion Starter · #18 ·
I believe we are just referring to the weight of the wheels here.
any aluminum clincher wheelset less than 1400 grams will probably sound like chaching$$$, the sound of money you'll be forced to spend sooner rather than later for a replacement. For light aluminum clinchers 1400g-1500g is the equilibrium point between reliability and lightweight. 1300g? no thanks. <1200g? GTFOH!
mrwirey
Cni2i,
Hola. I've had good luck with and been very happy with Boyd Wheels. I have two sets of their aluminum clinchers (Vitesse and Altamont) and one set of their 44mm Carbon Clinchers with a PowerTap rear hub. I've been toying with the idea of getting a set of their 28mm Carbon Clinchers for my No. 22 build. They fall into the 'lightweight' category at 1,311 gramms for the set. you may want to check them out. The Boyd peeps are very responsive to questions.
2016 28mm clincher wheel set - Boyd Cycling
Very respectfully, Tim
P.S. My LBS has had no luck getting my eTap groupsets (one for the No. 22 and I'm gonna put another set on my Madone 7s ... The latest ETA is sometime in June
1 - 20 of 27 Posts
