So I changed my left shifter cable this week end and I'm not sure it is trimming right, I follow the instructions an align the white marks on the FD near the pinch bolt it shifts good up and down(50-34 chain rings), but it does seem to take a little more force to shift up to big ring, also it doesn't seem to trim down as much when in big ring, I have a ultegra 11-34 cassette, and it will start rubbing the FD cage(50t chain ring) in the 5th gear(19t) I then trim down one click and will stop until its gets to 9th gear(27t) and starts rubbing the FD cage again and will not stop till I drop to the small chainring, does this sound normal for these shifters, I was thinking before cable change that I could trim down in big ring and get to to 27t cog on back, and not have to drop to small chain till i went past the 27t cog. I know about cross chaining, and I dont usually go past 27t cog in big chain ring. My gears on cassette are(11-13-15-17-19-21-23-25-27-30-34) So does this sound like the trim is functioning normal?
