I just use a dry rag to wipe the bike and components. If there's sticky stuff I'll put a little water on the rag. I tried the "pro mechanic" method with soap, water, and a brush and found that things started to rust after 2-3 years. Not an issue if you're swapping the bike out every year but I think it's a bad idea to expose the bike to water any more than necessary. I'll wet a rag with odorless mineral spirits to floss between the cassette cogs.What soap/degreaser, lube, brushes, etc. do you guys use for cleaning your bikes?
Did you dry and relube after cleaning?I just use a dry rag to wipe the bike and components. If there's sticky stuff I'll put a little water on the rag. I tried the "pro mechanic" method with soap, water, and a brush and found that things started to rust after 2-3 years. Not an issue if you're swapping the bike out every year but I think it's a bad idea to expose the bike to water any more than necessary. I'll wet a rag with odorless mineral spirits to floss between the cassette cogs.
nope. do you worry about your car wash soap being biodegradable?Are you guys worried about the dish soap being bio-degradable?
No one cares about the crap they put into the ground, at least not in the area of the U.S. in which I live (Southeastern Virginia).Are you guys worried about the dish soap being bio-degradable?
nice!I'm trying the WD-40 products after cxwrench turn me on to their dry lube.
The degreaser seems to work like a charm on the chain and drive train.
I was using some dish soap on the frames, no real difference between it and spraying the WD40 product on (less suds maybe).
As I hate dragging a stand outside to do this work, I broke down and bought a wall mount clamp, put a 4x4 in the ground with 240lbs of sackcrete, couple of carriage bolts and wing nuts (the carriage bolts stay in the 4x4 - clamp is easy to attach and remove - to keep it out of the weather). I'm in a year round riding area.
I don't wash my own car - I got to one of those self-service things where they have a drain.nope. do you worry about your car wash soap being biodegradable?
I don't think that's an excuse.No one cares about the crap they put into the ground, at least not in the area of the U.S. in which I live (Southeastern Virginia).
Almost any soap you would buy (like Dawn) is biodegradable. There are even lawn treatments that mix beer and dish soap. Your fears are groundless.IAt any rate, won't the soap kill any plants it comes in contact with?
Didn't know that. Positive?Almost any soap you would buy (like Dawn) is biodegradable. There are even lawn treatments that mix beer and dish soap. Your fears are groundless.
Would I just make it up?Didn't know that. Positive?
With the exception of industrial cleaners I would have to make a serious effort just to purchase.... aren't most soaps are bio-degradable? The I don't have to worry about ground-water run off on my property. And... the suds actually break the surface tension on my grass... making water and fertilizer absorption better. So no... I am pretty green... and no worries about using soap... or oil on my bicycle chain.Are you guys worried about the dish soap being bio-degradable?
Nice!.... I broke down and bought a wall mount clamp, put a 4x4 in the ground ....... clamp is easy to attach and remove - to keep it out of the weather).
Touché.Would I just make it up?
