1 - 16 of 16 Posts
Most of my lycra shorts are pretty thrashed and not really decent to wear without tights. So now that I mostly just commute I was thinking of getting some baggy shorts or knickers for the warmer months. What's good that doesn't cost $100? Closer to $50 would be best. Thanks.
Yo no fui.
When I don't feel like wearing a road kit, I just use cheap bike shorts with swim trunk board shorts over them. Fox also makes some pretty good bike short baggies I've used.
Downhill Juggernaut
Ditto.
I like to wear tri shorts with the thinner pad on underneath and board shorts or similar over it.
duh...
cheapest way is to get something, whatever you like, to wear over your shorts. baggies can be hot, and if you're just getting 1 pair they will sit in the hamper more than you wear them. some baggies have removable liner shorts, but you can't always buy those separately. since you've already got shorts, I say use those
Yo no fui.
Chris H said:
Ditto.
You can mix and match and use the bike shorts under other pants or knickers as well.
Plus, on the off chance that you pass a bikini pool party on the way home, you'll be set. :thumbsup:
Premium Member
REI Outlet has some deals. Or visit a store if there's one near you.
I've been using chamois liners, Swobo, etc under knickers, baggies, whatever...
Climbing shorts/knickers are nice. I have a heavier pair for winter, but will probably try some lighter summer versions soon. They are made the same way as cycling shorts, with a taller rear section, to prevent lower back irritation from a harness.
Mountain Gear has a bunch of selections.
1 - 16 of 16 Posts
