1 - 15 of 15 Posts
· Punster
I just got my 3T Ergonova LTD handlebars from ProBikeKit(in 1 week!). They don't seem to come with any installation instructions, and I couldn't find any product manual on the 3T website.
What should I be torquing the stem-handlebar clamp to? And how about the shifters?
I just have a 2 bolt Bontrager stem right now, but I'll probably get a 4 bolt unit soon.
Thanks.
Thanks.
Torque is rotational force as exerted on a bolt or screw. Since the handlebar doesn't have any bolts or screws, the manufacturer can't give you any values. You need to use the values given by the stem- and shifter manufacturers, or use a general guideline like the one on the Park Tool website.
thoughts...
A good carbon bar should not have critical torque limitations. Most 4-bolt face plates recommend 5Nm of torque. I've never put a torque wrench to the band clamp bolts, but Shimano lists a torque of 6-8Nm in their instructions.
I still recommend to those who want to learn bike mechanics to learn what those small torques feel like, by hand, and not become so dependent on a torque wrench. I've never put a torque wrench on any M5 or M6 bolt.
· More carbon fiber please!
wim said:
been200mph said:
I still retorque head stud nuts on my race motors after initial run-in/dyno pulls. :)
Beautiful,wow! What's with the optional connection—different response to the pedal?
That's where the throttle linkage hooks to. You can manipulate the linkage a bit to change leverage/feel at the pedal. With a pair of carburetors it takes a bit to open both of them up. It's a little 331" small block Chevy ready to dyno. Should make right at about 700 hp hopefully. Heads are conventional port layout 23 degree style thus no huge power numbers. But as with the bike stuff... lol... notice the carbon fiber hood scoop (this is for my dragster thus the scoop mounted right to the carbs), and you can't see the titanium valves and valve spring retainers under the valve covers. Also has an external belt-driven oil pump, along with vacuum pump up front, and belt-drive for the cam and front belt-driven distributor.
ps... my race helmet is also carbon fiber, lol. As is my head & neck restraint. Can't get enough c/f! :)
· So. Calif.
Thanks.
Also apply a thin smear of carbon assembly paste, to the contact surfaces between carbon and aluminum, or carbon-to-carbon. It increases the friction so that no slipping, or creaking, will occur.
I am torquing my 3T Arx Team stem (alloy) and 3T Ergosum Arx Team bars (carbon) to 5 N-m, that is 3T's spec -- I think the instruction sheet came with the 3T stem. Works fine.
Whether it's a 2 or 4 bolt faceplate on stem, alternately tighten screws in increments, so the gaps remain uniform.
have you ever "calibrated" your torque feel? or somehow measured it to see if it's reliable/ reproducible? i think experience counts for a lot but i would think it would be very subjective depending on conditions, e.g., at the end of the day and you're tired you think you're putting 5N-m but you're actually doing 3N-m.
I found that in the past, it was easier to get a feel for higher torque values (~40nm+) than for low ones (<10nm). YMMV.
+1.
*but*, if you're going to use a wrench, know that they aren't all that either. the 'click' style need to be regularly recalibrated and detensioned after every use. the 'beam' style lack precision. the best are the dial versions, a la snapon torquometer. an inaccurate wrench might as well be no wrench at all...
1 - 15 of 15 Posts
