I have been searching the forums trying to find someone that is using the 12g CO2 Cartridges for fixing flats but all I see is the debates for 23mm tires... Because of my weight of 250lbs I am switching from 23mm to 25mm Gator Skins and would like to know if I can get away with using some 12g carts of the 16g carts? I used a 16 yesterday 2 different times for flats:mad2: and both times I ended up wasting some of the CO2 because I felt like my tire had more than plenty air in it.. But then again I am currently running 23mm times.. Basically I am looking for something to keep me from being stranded so Max PSI may not have to be achieved but it needs to be enough to support my 250lbs.. So do you think a 12g will work or should I stay with the more expensive 16g's... I am using a threaded Micro inflate.. Also does anyone know if the CO2 Carts at WalMart are threaded or not threaded?
