When you're building a rear wheel, does the build typically go like this: lace spokes to hub and nipples, dish rear wheel and tension drive side spokes, then tension non-drive side? Or, do you apply tension evenly?
I'm asking this because I have a problem. I recently got my wheelset that has CK hubs with A23's, and DT comp spokes. The non-drive side spokes worked loose very fast - I went for a ride through Bastrop park, and some of the spokes were so loose that I could turn the nipple by hand.
I feel I can tighten them up fairly easily with a spoke wrench, and even bring it fairly true too (used to do that with bikes when I was younger), but wondering if I should just trust it to a lbs. Yes, I have contacted the builder and am awaiting a response. I'm thinking that the builder just forgot to finish the rear wheel.
