1 - 12 of 12 Posts
your text here
I have a CX bike I use for trails and towing The Kid around town. I currently have canti brakes and noticed over the past two years, as The Kid gets bigger, the braking leaves much to be desired. I can still brake, but there were a few times on vacation last year that descending raised my heartbeat a bit.
I have been looking at getting BB7 Road calipers and some 29er wheels (deore/a317). Is this worth the $250 upgrade?
Is your frame/fork already disc compatible? If so, that simplifies things a bit.
What canti's are you running now? You might try a different brake (wide profile) like a Tektro CR720 and some different pads. If you take the time to set up cantis well, they'll stop pretty much anything.
your text here
frame and fork are disc compatible.
i have some shortys on right now. i thought about the cr720, but wasnt sure they would give the same grab as discs.
and i would never race this thing, so that (soon to be removed?) rule doesnt apply to me.
Quick comments
One thing you might need to be carful about is how your kid trailer attaches to the bike. a lot of trailer hitches are not compatible with disk brakes.
That said disk brakes can be a good investment and will provide plenty of stopping power but a cheaper way to go would be to switch to a V-style brake. V brakes will give you the same stopping power with about the same lever feel as a disk brake in just about any condition other than in the really wet. (I.e. one/two finger braking that will lock the wheels).
For V brakes I would recommend the Avid SD-7 or SL or what I now run; the Cane Creek Direct Curve brakes.
Another route to go would be the Paul Components Neo-Retro brakes. I have not tried them but have heard very good things.
http://www.sram.com/en/avid/rimbrakes/index.php
http://www.canecreek.com/direct-curve-3-brakes.html
http://paulcomp.com/
NeoRetroGrouch
I have not found V-brakes to be much of an improvement with road levers - with or without Travel Agents. You will find that just a front disc will be a huge improvement. - TF
I had shorty's and the front sucked, the rear was so so. I listed that bike 2-3 times on craigs list because I couldn't get the brakes to inspire confidence (I tried all kinds of adj and straddles) and I was looking at getting a cross with disk. Since it didn't sell I tried a cheap set of cr-720 and I am loving it. It probably isn't as great as disks specially in the wet and depending on the load but it was 18.48 a pair at tree fort with shipping.
http://www.treefortbikes.com/107_333222344377__CR720-Cantilever-Brake-Front-or-Rear.html
Formosan Cyclocross
Avids are more common, but I use Shimano BR 505R. They work great for the traffic dodging I have to do and nice in the slop. Besides, they're easier on the rims. My rims look relatively pristine compared to other brakes. If you have the dough... why not.
Disk brakes are very nice. Could you just put disk compatible wheel on the front with disk?
I have shorties as well and they don't really inspire confidence in braking
your text here
Discussion Starter · #10 ·
i thought about running a mullet, but the rear brake really has no stopping power. plus, when you get down to it, i can get that wheelset pretty cheap, and the calipers run <$60 per.
current wheels have three really hard years on them and are starting to lose tension to keep the wheel true.
i have a chariot cart, so discs should be no problem.
abominable slowman
I have Paul touring brakes on my cross bike. They're better than most other cantis I've tried but not as good as discs (which I have on my mtb). Switching just the front to disc seems like a good idea.
Yes, it is worth it in my experience. I have BB7's on my Lemond and pull 2 kids in our Chariot. Bike stops fine. The peace of mind is priceless.
singlecross
1 - 12 of 12 Posts
