1 - 9 of 9 Posts
Steaming piles of opinion
lawrence said:
I'm getting a new set of wheels. Of course I'm keeping my old set. Should I loosen the spoke tension before I store them?
No.
They're far stronger and less susceptible to damage strung and tensioned.
What up, dog?
Are you a skier by chance? If you are, then I know where this question is coming from.
I always chuckle when I see all the "should I take the tension off my bindings" posts at the end of each ski season... People will wear out before those springs do!
I never mess with wheels unless they're turning into tacos, and would NEVER consider backing off spoke tension.
Yes, de-tension all spokes!
I heard this question before, years ago, and did a drawing on it for a cycling newsletter April 1 issue. Don't ask me how many people took this for good science . . .:p
Adorable Furry Hombre
Spoke Wrench said:
I always make a point of speaking affirmingly to my spare wheels. That way they won't be so stressed. It works too! I've never had a spare wheel pop a spoke.
O contraire,
I always allow my radially laced hoops to listen to some heavy metal.Get that whole learning by osmosis thing going.
HTH NTTAWWT TIA FWIW YMMV
Resident Dutchbag
Nevermind the pack mentality, it seems peer pressure is still rampant among the so-called adults here. The answer is, no. Under no circumstance loosen or tighten the spoke tension when you're not trueing a wheel.
1 - 9 of 9 Posts
