So my new Reynolds Assault wheels are great wheels. Braking is solid and predictable and the wheel flex is non-existent. The only issue I am annoyed by is the wheels at 35mph+ speeds. The wheels at high speeds start to feel like they are out of round or out of balance if that makes sense. The wheels have a surging feeling. That is the best way I can describe it. Here in New Mexico, there are lots of steep descents that are pretty short so I get it often. It is un-nerving as it increases as speed increases to 40mph. I don't feel out of control, but in a cross wind it could get exciting. I un-mounted the tires and put the wheels in my truing stand. Both wheels are round within a millimeter, and when spun don't have a noticeable unbalanced spot. The wheel simply comes to a stop at different places each time. Could the lightweight rim be that affected by the 60mm valve stem weight that it un-balances it at high speeds? If it does, I am guessing a spoke magnet opposite the valve stem might work. Obviously with a mounted tire in the truing stand, the valve stem always ends up at the bottom, which you would expect in a balanced wheel.
