....and bearing drag is totally insignificant. Even if you have the worst bearings out there, there is little room for improvement in terms of speed/performance. You could probably help longevity by getting better bearings but that's it.Because heavy wheels that are poorly built are still crap even with good bearings.
Exactly. What you want to reduce is your rotational mass (see: Rotational Mass). Lower friction / lighter bearings will allow your wheels to spin slightly smoother, but you'll still be rotating a heavy mass about them. To gain the greatest efficiency, a lighter wheel set is what you need. That's why when people put heavy rims on a car, it becomes harder for the car to accelerate and also harder for the car to stop, because rotational mass is working against the direction the car is trying to go. Don't spend the money on ceramic bearings...look for a good deal on nicer set of rims. I too have Bontrager Selects because I just started road biking and wanted to do so on a budget; I'll be upgrading wheels later this year.....and bearing drag is totally insignificant.
Unless you're a competitive racer, rotational mass makes no difference, but, of course, total mass does, when your climbing.Exactly. What you want to reduce is your rotational mass
I guess it depends on what you're going for; since lighter wheels spin easier than heavy wheels, one should be able to ride the bike with less effort, making for a more enjoyable, more sustainable ride.Unless you're a competitive racer, rotational mass makes no difference, but, of course, total mass does, when your climbing.
On the flats weight is virtually meaningless. It increases rolling resistance in the smallest way by causing the tires to flex a tiny bit more. 450 grams (1 lb.) decreases speed by about 0.02 mph (0.03 km/hr) - that's three seconds per hour at 20 mph (32 km/hr).I guess it depends on what you're going for; since lighter wheels spin easier than heavy wheels, one should be able to ride the bike with less effort, making for a more enjoyable, more sustainable ride.
because they're useless on bicycles.As it says I have a ok set of rims. I'm thinking of upgrading why not get some great ceramic bearings instead of entire rims? I have bontrager select now.
Bearings on your bike dont spin that fast. On the internet my bike will combust if I dont have them. In real life, not so much. But on the internet.........Ceramics have great applications in high speed bearings. Bearings on bikes don't spin that fast. I have ceramics in the freehub on one of my wheels. I needed two 6803 bearings and the distributor sent the ceramics instead of what I ordered. Didn't notice until it was all apart so I put them in. Suprisingly enough, I didn't get faster or smoother.
