bauerb said:
I got a great deal on an 03 Bianchi Eros($250). trouble is that it is a 49". I am 5'10 with an inseam of 30". If I were sized for a bike, I'd likely be a 54". so the 49" is 5cm or about 2" smaller than ideal. I don;t want to look like an ape at the circus on a tiny bike, but I also see the pro's riding bikes where it looks like their calves go above the top tube when they petal. so maybe I need a longer reach stem, or to push the seat bike. I don't have the option financially to get a new bike, so I'm trying to make this work. should I be ok with some tweaking? or is this a non-starter?
thanks
I can't say for sure one way or the other about the fit of the bike (thought I'd guess it's too small)--you'll have to judge that for yourself. What I CAN give you is a couple of things to look out for.
1. How much seatpost is showing when it's set up for you? If it's WAY too small, especially if it's a compact frame, you might not be able to get a seatpost long enough. Also, if you're heavy, and the seatpost is way extended, you might flex or bend it.
2. How's the drop to the bars? Lay a straightedge on the top of the saddle when the saddle height is set up for you--measure down from that level to the bars. The pros often have a prodigious drop--10 cm or more. Most "normal" people don't want anywhere near that. 4-7 cm is pretty sporty, and if you're new to riding you're probably going to be more comfortable with your bars nearly level to your saddle. It depends on your flexibility, etc., but I'm guessing you'll have a massive drop on this bike.
3. How's the reach? If the bike is too short front-to-back, you're going to feel all wadded up. This can be fixed a bit with a long stem, but that can have a pretty serious adverse effect on handling.
4. Can you get a good position over the cranks/bottom bracket? If you don't know what you like, try starting with getting your knee over the pedal spindle (just do a search here on KOPS and you'll see how to set it up if you don't already know). With an undersized frame, you may have quite a bit of difficulty getting that set up. This is one thing you can't adjust away, either.
There are some other potential issues, but these are the ones that stick out in my mind.
