82 degres is a minus 8 from 90 and and 84 is a minus 6. Minus 6 is HIGHER than a minus 8. A 90 degree is also know as a zero degree and it's higher still.dougn said:82 degree will provide the most height. the greater deviation from 90 degrees......
C-40 said:You guys need to get your terminology straight. If you want to compare flipped stems, then use the correct angle. A flipped 82 is a 98 and a flipped 84 is a 96. The original post asked about an 82 and an 84. Most stems are NOT flipped up. A flipped stem would be extreme rarity on any real race bike.
first off i suspect you knew what the person meant
who are you or anyone else to define a convention...and a poor one at that
most stems are flipped up
mine is flipped up and i have a 4.5 inch drop to my handle bars. it all depends on specific frame size, and set-up.
dougn said:I assumed the poster knew the standard nomenclature, and answered correctly. You're the one who's confused. I didn't make up the standard, the manufacturers did. All seem to go by this standard, where the angle is measured counterclockwise using either the steering tube centerline as the reference line, or a line perpendicular to the steering tube. The high rise angle would be 98 degree or +8, not 82.C-40 said:You guys need to get your terminology straight. If you want to compare flipped stems, then use the correct angle. A flipped 82 is a 98 and a flipped 84 is a 96. The original post asked about an 82 and an 84. Most stems are NOT flipped up. A flipped stem would be extreme rarity on any real race bike.
Here's the Deda Newton drawing:
And yet they don't seem to refer to it as a 98, nor do they have a separate catalog listing for a 98.C-40 said:I assumed the poster knew the standard nomenclature, and answered correctly. You're the one who's confused. I didn't make up the standard, the manufacturers did. All seem to go by this standard, where the angle is measured counterclockwise using either the steering tube centerline as the reference line, or a line perpendicular to the steering tube. The high rise angle would be 98 degree or +8, not 82.
So....when people talk about a 73 deg. seat tube it may also be 107 deg. because you ride your bike backward?dougn said:first off i suspect you knew what the person meant
Sorry dude, C-40 is correct on this one. It's either 82 or 98.danl1 said:And yet they don't seem to refer to it as a 98, nor do they have a separate catalog listing for a 98.
The "98" nomenclature necessary for your argument is anything but a standard, though some few folks do refer to it in that manner. For every one that does call it a 98, "82 with reverse assembly" or similar would be used by a few thousand, including Deda.
http://www.dedaelementi.com/dettaglio.asp?articolo=121
The correct answer (already given by the folks that "don't know their nomenclature") is that the 82 gives more height if flipped up/reversed, the 84 if flipped down. That answers the question without making any assumptions as to the OP's intent WRT the ambiguity. It also avoids looking like a putz for arguing a point that your own reference refutes.
At least we're past the quill-stem days, where the angle was often listed as rise from horizontal, assuming a 'standard' HTA, even though each manufacturer had a different idea of 'standard.' For example, a stem that today we would call a -17 or a 73 would be called a 0 degree rise, give or take a degree. This is the reason for the current "degrees from parallel to steerer" (eg 84 degrees) road standard. Back when the transition to threadless was happening, there was considerable confusion as to whether "6 degree stem" meant six degrees off of horizontal or off of the steerer, especially since the standards converge at about that point. Since MTB's were usually pointed up (and there was more MTB threadless than road threadless at the time) the chances for confusion were plentiful. Changing to the new nomenclature resolved one ambiguity, but created another. Fortunately, this one can be worked out independently, while the other could not.
I've quoted deda as "86 reversed" previously.LBK said:Sorry dude, C-40 is correct on this one. It's either 82 or 98.
Trigonometry doesn't Lie. I built a spreadsheet last year because I was changing out stems and wanted to compute the differential in height with various alternatives, and solved for rise using high school trig. I plugged in an 11cm stem on a 73 degree head tube and it produces .38cm (about 4mm) more height with an 84 vs. an 82. If you go to a 14mm, it's about 5mm more rise. C-40 is right, and I have the math to prove it.C-40 said:height will be produced with an 84 degree, with an average 110mm length. Shorter stem will be a bit less and longer ones a bit more. This assumes the same steeering tube clamp height.
