I've been riding the stock Specialized Espoir Sport 700x25c tires with BlackBelt puncture protection that came on my bike when I bought it (370 grams per Specy site Specialized Bicycle Components ), but the rear is worn out and so it's time for at least a rear tire. I didn't rotate them and have heard that I should have to make them last longer.
Locally I have Specialized dealer, Performance Bike and several other LBS. After reading around it seems about 230g is a good weight for everyday reliable road tire. I've been riding every other day about 20 miles and once or twice a week 35 miles in flat to very hilly terrain. Thinking of going to 23mm tire, but not sure, I'm about 190lbs and ride all year all weather, rain or shine.
Local Specialized dealer has many Specialized tires to choose from and guy recommended these three.
Turbo Elite...$30 each
Casing: 60 TPI
Bead: Foldable
Center Compound: 70a / Shoulder Compound: 60a
Flat Protection: BlackBelt
700 x 23; psi 115-125; approx. weight 245g
Turbo Pro...$50
Casing: 127 TPI
Bead: Foldable
700 x 23; psi 115-125; approx. weight 200g
700 x 25; psi 115-125; approx. weight 220g
Roubaix...$55
Casing: Endurant 120 TPI
Bead: Foldable
Flat Protection: Endurant Casing and BlackBelt
700 x 23/25; psi 115-125; approx. weight 260g
700 x 25/28; psi 115-125; approx. weight 300g
Performance has:
Hutchinson Fusion 3...buddy likes them, but I read couple reviews about them blowing off the rim, on sale $40
The best compromise between GRIP/PERFORMANCE/RESISTANCE
Triple compound
- hard rubber in the centre to improve wear and resistance to cuts and perforations, while also lowering rolling resistance
- Softer intermediate rubber to guaranty progressive accelerations in corners and safety thanks to a high level of grip
- Very soft lateral rubber for an unequalled grip in the tightest corners.
Kevlar Pro Tech
100% Kevlar reinforcement under the tread to increase the tire’s resistance to perforations and punctures by more than 50% without compromising performance.
210 grams
Hutchinson Tire : FUSION 3 - Kevlar ProTech
Michellin Pro 3...another buddy likes these, looks like discontinued they are not on Michellin's site anymore....on sale $40
Moto GP compound with Silica Energy rubber provides extra grip on the shoulders while lowering rolling resistance in the center
High Density Puncture Protector nylon belt delivers outstanding puncture resistance
High Protect Rim System protects the tire from rim bead friction
Pro 3 Race road tire's extra supple casing with 127 TPI and cross-ply fibers add flexibility, performance and light weight
No weight spec
Michelin Pro 3 Race Road Tire - Road Bike Tires
Michellin Pro4 Endurance or Service Course...on sale $55 and $60 respectively
Dual-compound tread ensures exceptional resistance to wear and enhanced grip when leaning through corners
The compound employed for the shoulders provides a very high level of grip on wet roads, while the compound used for the central part of the tread delivers greater protection against punctures and impact damage.
The combination of the 110 TPI casing and bead-to-bead breaker ply ensures outstanding resistance to perforation and contributes to the tire's remarkable durability
No weight spec
Michelin Bicycle USA - A better way forward®
Forte Pro Plus (the bead area of the tires seemed really thick and not very flexy for a folding tire)
Dual compound tread improves wear resistance, boosts traction in the climbs and provides faster center-line acceleration
Low rolling resistance improves cornering confidence at higher speeds
Armor Clad Technology provides durable bead-to-bead protection against sidewall cuts, abrasions and tread punctures, yet is thin and flexible enough that it doesn't compromise ride quality
120 TPI casing ensures a supple, stable ride
252 grams per PB site (package stated 235 grams...lol)
Forté Pro+ Road Tire - Road Bike Tires
I'd like to buy a tire locally if possible since rear is about shot, recommendations please.
Casing: 60 TPI
Bead: Foldable
Turbo Pro...$50
Casing: 127 TPI
Bead: Foldable
Roubaix...$55
Bead: Foldable
Performance has:
Triple compound
Kevlar Pro Tech
210 grams
No weight spec
No weight spec
